Old 01-Dec-2006, 20:00   #1
9rrr 9rrr is offline
Choke advice 996r
Any you guys running Brembo aftermarket Clutch radial master cylinders. What did you do to secure the choke as it is normally secured by a small pin. Aftermarket one dosnt have this facility. Is it just going to spin around when I try and use the choke. Help.
Old 01-Dec-2006, 21:17   #2
On my 998 i did away with the choke cable and fitted a 916 throttle assembly with the fast idle button on the underside
Old 01-Dec-2006, 22:18   #3
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
I will have to check what I did 9rrr. I too have the brembo radial clutch, but for the life of me, can't remember if I had prob's with the fast idle. I will take a look tomorrow and let you know.
Old 02-Dec-2006, 06:50   #4
khu996 khu996 is offline
khu996's Avatar
Im in the same boat. I havent secured it properly, just left it wedged between the switches and clutch cylinder. Would also welcome a more tidy suggestion!
Old 02-Dec-2006, 07:30   #5
khushy khushy is offline
khushy's Avatar
on my 999
the choke cable was too short when I fitted wider bars and the brembo MC so for a while I thought I will just discoonect it altogether - that was 18 months ago - I havent used the choke since at all!
Khushy
PS and no it doesnt idle at 3000 rpm either!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:02.
