Old 02-Dec-2006, 18:22   #1
Tonio600 Tonio600 is offline
Tonio600's Avatar
Mood: What a wonderful world.
Hydraulic male / male adaptor for oil cooler fitting
In the process of fitting a 916 oil cooler on the DD bike, I'm looking for 2 male / male adaptors to connect the pipes to the crankcase.
So I found those on Ebay:
http://cgi.ebay.co.uk/HYDRAULIC-MALE...QQcmdZViewItem
But guess what, I don't understand anything about the sizes
... And me thinking all modern countries use metric sizes
Have been mesuring the outside diameter of the thread I need, it's 14mm (M14?).
Thanks in advance for your help.
Tonio.
Old 02-Dec-2006, 19:46   #2
They won't fit Tonio. The Ducati fittings are M14 metric threads.
Old 02-Dec-2006, 20:04   #3
paynep's Avatar
Mood: Wet wet wet
Tonio, I'm pretty sure that I have the crankcase fittings off a 916 in the garage. I'll check tomorrow and if I have you can have them for the price of a pint!
Old 02-Dec-2006, 20:12   #4
bolds bolds is offline
£4.93 each from Ducati
Old 02-Dec-2006, 20:21   #5
Tonio600's Avatar
Cheers Nelly I had the hope that the sizes in the ad were equivalent to M14 but I'm glad you confirm thay're not.
Old 02-Dec-2006, 20:23   #6
Tonio600's Avatar
Hi Paul,
Thanks for the offer, I'll take you on it
Tonio.
Old 02-Dec-2006, 21:53   #7
Zimbo16 Zimbo16 is offline
Zimbo16's Avatar
Mood: Feeling peckish
If not your local hydraulics fitting shop will keep them in stock Tonio, not difficult to get hold of at all. They should have them on the shelf for not much money.
Old 02-Dec-2006, 22:08   #8
Tonio600's Avatar
What do you mean by local hydraulics fitting shop? Homebase?
Things need to be simple for me
BVut thanks for the advice, if Paul can't sort me out I'll try to see what is in the area...
Old 02-Dec-2006, 22:30   #9
Zimbo16's Avatar
No, not Homebase! You're bound to have a hydraulics shop close to you, possibly on an industrial estate, have a look in Yellow Pages. It's a place that makes up hydraulic hoses and supplies hydraulic fittings and components.
if you get stuck let me know and I'll get you a couple from my local place, I use them all the time for work supplies.
Old 02-Dec-2006, 22:35   #10
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Just make sure you are buying the right sort of fittings for the hoses that you have. Some require taper, JIC, seats. Some are a square end where the hose end seats inside the fitting and seals with an O ring.
Sorry to add to your confusion, post a pic of your hoses, and we can go from there.
Rgds,
Rob
