Old 16-Oct-2003, 18:46   #1
DJ Tera DJ Tera is offline
Great Timing - NOT
Off to Magny Cours in a couple of days and the 998 has decided it wants to leak oil
Started it up last night and could smell burning oil and could see the smoke thru the headlight beams.
There isnt any coming out the exhausts.
It looks like its leaking a little and then as the engine/pipes heat up it burns this oil.
Theres a little in the bellypan and stains on the downpipess
Any suggestions? Could it be the pressure switch?
Old 16-Oct-2003, 19:18   #2
JACKO748S JACKO748S is offline
JACKO748S's Avatar
Sorry to hear that mate. I can't help but just thought you could do with a bit of sympathy. Sods law is a bugger sometimes.
Good luck with sorting it.
Jacko.
Old 16-Oct-2003, 19:23   #3
its under warranty so if i dont get it sorted in time I will just claim ignorance
thanks for the sympathy though!
[Edited on 16-10-2003 by DJTera]
Old 16-Oct-2003, 20:52   #4
John W John W is offline
John W's Avatar
assuming you've taken a side panel off, can you see any oil around the pressure switch ?
Mine went a few weeks back and the trace of oil is pretty obvious.
Apart from that I would suggest firing it up with the panel off and seeing if you can track it down.
I had a hole in the oil cooler too, and believe me that one was hard to miss !
Cheers,
John.
Old 17-Oct-2003, 09:39   #5
what about the oil cooler pipe connections, mine did this and it was the connectors to the engine ally washer. Right hand side engine, just above behind battery. drips onto the oil filter, then downonto the front exhaust.
Old 17-Oct-2003, 11:22   #6
Originally posted by weeksy
mATE,
Worst case scenario you can lend mine for the trip on a bend it your Daddy buys it
you'll need to supply your own bodywork and i'll expect a pint out of it.
cheeky git
I bought the duke out me own money with cold hard cash
Thanks for the offer though matey, will try to see where the leaks coming from later and let you know
998 track fairings would fit straight on wont they?
Old 17-Oct-2003, 18:42   #7
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
Just check the sump plug.
Jon
Old 17-Oct-2003, 22:19   #8
yeah i think i forgot to replace the washer - casoli didnt say anything about it tho when i bought a filter off em - wont be taking my bike for a service there then!!!
Old 20-Oct-2003, 17:01   #9
pguenet pguenet is offline
DJT, maybe your bike has a self defense mechanism after all... seeing how badly the pipes have been rusting she decided to bleed some oil in an attempt to healing herself...
Seriously, try the crankcase covers. It could be just a question of the sealing going away.
Copper washers not changed on an oil change also could be the reason indeed.
I hope Magny was OK.
p
[Edited on 20-10-2003 by pguenet]
Old 20-Oct-2003, 20:50   #10
thrustercat
check the 22mm sump washer. I had exactly the same symptoms a while back. I found out that the washer was incorrectly seated and the oil was dripping onto the exhaust and causing it to smoke.
good luck
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:14.
