Old 11-Dec-2006, 15:02   #1
Loz ST2 Loz ST2 is offline
Loz ST2's Avatar
KPH to MPH speedo
Does anybody know where you can get on off those stick-on converters from KPH to MPH that you place over the face of the speedo.
Old 11-Dec-2006, 15:03   #2
I think Ducati UK will send you one if you call them.
Old 11-Dec-2006, 15:07   #3
MPH speedos also come up quite regularly on eBay for not too much dosh.
___________^
Old 11-Dec-2006, 15:54   #4
phil_h phil_h is offline
phil_h's Avatar
If you want a mechanical convertor that fits between the speedo cable and the speedo pm me as I have one off an old bike that should fit.
Old 11-Dec-2006, 18:07   #5
doogalman's Avatar
I'd possibly be up for it if Loz ain't interested.
Old 11-Dec-2006, 20:59   #6
Loz ST2's Avatar
How does the machanical converter work, as you would still have the dial in KPH. Have seen a couple of speedos but they are asking about £90-£100.
Old 11-Dec-2006, 22:25   #7
the phantom pieman the phantom pieman is offline
the phantom pieman's Avatar
Mood: Sort of shuffling along .....
Does a KPH speedo mean an MOT fail?
Old 12-Dec-2006, 16:59   #8
Derek Derek is offline
Bikes: ST4s ABS
Derek's Avatar
The mechanical convertor is a tiny gearbox that goes between the cable and the speedo (or between the cable and the wheel unit on some models). It reduces the speed of the cable so that the speedo reads mph instead of kph. To make it legal you will need to cover the kph legend on the dial with an mph one. The convertor is better than a sticker because not only does the speedo read mph directly but the trip and odometer read in miles as well.
The speedo is not part of the Mot.
Old 13-Dec-2006, 08:23   #9
Loz ST2's Avatar
Derek many thanks for the offer, but it looks like I might of have found a speedo. Over to you doogalman if you are still intrested.
Old 13-Dec-2006, 14:57   #10
doogalman's Avatar
Phil H you have u2u.
