Old 05-May-2015, 13:07   #1
r15suk r15suk is offline
r15suk's Avatar
Clutch Pressure Plate Movement
Can anyone please tell me the distance the pressure plate should move out when the clutch lever is pulled fully in?
I've heard that the movement should only be 1 - 1.2 mm
cheers
Simon
Old 05-May-2015, 18:57   #2
dunlop0_1's Avatar
Not sure about the measurement but I like to be able to turn the pressure plate with my fingers with the lever pulled back.
Old 05-May-2015, 23:03   #3
r15suk's Avatar
Thanks for the info. Mine is moving so much that the end friction plate pops out of the basket :-0
Old 06-May-2015, 06:27   #4
dunlop0_1's Avatar
The hydraulic movement of the push-rod/cylinder should not alter as it is fixed. If anything wear or air in the system would create less movement. Sounds more like the stack is incorrect/rusty/dirty or has too many plates. Possible drum issue so It really needs a complete strip down.
Old 06-May-2015, 12:58   #5
r15suk's Avatar
Stack height is correct as spec 38mm (Haynes) and its quite new. The issue only came about when I fitted a lever with a greater span adjustment and could pull it back to the bar further. This translated into more clutch movement and off popped the plate. I have an Oberon slave fitted so maybe this allows more piston movement and hence more rod movement..
Old 06-May-2015, 22:28   #6
what clutch spring caps do you have
Old 07-May-2015, 06:27   #7
dunlop0_1's Avatar
I think you have answered your own question.
Old 07-May-2015, 10:29   #8
r15suk's Avatar
After market ones, but I'm not sure of the make. Can this make a difference?
cheers
Simon
Old 07-May-2015, 13:16   #9
If you've still got your originals it's worth comparing them to make sure they're the same depth. The 1098 and Hypermotard (and probably others) have different depth spring caps to change the clutch setup so you may have the wrong ones.
Old 07-May-2015, 13:36   #10
r15suk's Avatar
Thanks for that, i'll see if I still have them.
Simon
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:25.
