Old 16-Dec-2006, 12:02
TonyH's Avatar
TonyH TonyH is offline
Mood: Bits fitted service done, Nice
Final Gearing Changes
I'm changing the final gearing on my 748E and I've used 'Gear Commander' and other calculators to derive the new chain length.
I'm going to increase the number of teeth on the rear sprocket from 38 to 40 teeth giving a new ratio of 14/40 (stock 14/38) to get better acceleration and to compensate for the larger diameter sprocket and maintain the same amount of chain adjustment increase the chain length by 1 link from 94 to 95.
Just before I order the parts I would like to confirm that the new sizes are correct, has anybody done the same change and any comments would be appreciated.
Old 16-Dec-2006, 12:08
PDL's Avatar
PDL PDL is offline
Bikes: 803 rs race bike
I run 14/40 on mine BUT you will need a different sprocket carrier. The chain should come with additional links that you can take out at will.
Old 16-Dec-2006, 12:12
TonyH's Avatar
I've got a carrier and was going to order from B & C so I can specify the correct number of links just making sure I was right before splashing the cash
Old 16-Dec-2006, 12:57
You can only get chains in even number of links. The length you need is 96.
Old 16-Dec-2006, 16:04
TonyH's Avatar
Thanks Nelly for pointing that out its obvious when you think about it, which I obviously hadn't, hopefully there will still be enough adjustment to get full life out of the chain.
Old 16-Dec-2006, 18:39
Gizmo Gizmo is offline
Mood: is it the weekend yet??
you might want to check a tech article i added to upnorth Tony http://www.ducati-upnorth.com/tech/gearing.php its one of Shazaam's posts on suggested gearing and chain length.
Old 16-Dec-2006, 19:13
TonyH's Avatar
Thanks Gizmo, interesting point about the ride height as well
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 03:44.
