Old 19-Dec-2006, 01:48   #1
khu996 khu996 is offline
khu996's Avatar
Brake disc compatibility
Which later model brake discs are interchangeable....from the 748/748R/996/996R/998/998S or 998R?
Did read something about different offsets a while back, but after a little search, couldnt find the info.
Could someone clarify?
Old 19-Dec-2006, 10:34   #2
Hmmm - I think that its only the 748R disks that differ from the others. Not 100% sure on this though.
Tim
Old 19-Dec-2006, 11:39   #3
MARTIN H MARTIN H is offline
MARTIN H's Avatar
Not sure about the offsets but I know the 996r had slightly thinner discs than previous models?
Old 19-Dec-2006, 17:41   #4
I'm 99% sure that the the 748r and 998r have the shallower offset, while the 996r has the standard offset which means they will fit all other 6 bolt Ducatis
Old 19-Dec-2006, 19:21   #5
Bungi Bungi is offline
like the man says its only the ohlins model 748R and the 998R run a differant offset,
if your just looking at std production bikes, all others are interchangeable, but may have differances especially the centre
Old 20-Dec-2006, 01:08   #6
While on the subject where can I get a disc bobbin for my 748R discs (yes they have a different offset to my other Ducatis), would I better off trying the Brembo place at Silverstone or someone like JHP.
Only missing one then I can put them up for sale along with the Ohlins forks and bottom yoke
