Old 19-Dec-2006, 11:03   #1
bike mad bike mad is offline
bike mad's Avatar
for forks sake
I need help,
I have been told that you can't get different rated fork springs for a 999S with the ohlils forks and if I can does any one know the standard rating for a 999S biposta, I think the biposta is not the same as the mono, the rear works with a different spring,
The only spring I have been offered is a progressive hyper pro.
so please please help me out. any info would help.
just to know ohlins do a selection would help.
Old 19-Dec-2006, 11:08   #2
khu996 khu996 is offline
khu996's Avatar
Who told you that? Sounds like a load of cobblers to me.
Why can't you get different rated springs? As far as I know, they come with 9 or 9.5's and you can change them to whatever suits you.
Old 19-Dec-2006, 12:00   #3
bike mad's Avatar
I was told this by JHS Racing. How sure are you? Do you know anywhere I can get an ohlins spring?
Many thanks.
Old 19-Dec-2006, 12:41   #4
khu996's Avatar
I'm no suspension expert, give Nelly or JHP a call, they'll be able to advise you better.
But the point is, its a normal cartridge type fork assembly, why wouldn't the springs be changeable?
And why do you want to change them? Softer or heavier?
Old 19-Dec-2006, 18:47   #5
Give these guys a ring, sure they will put you on the right path.
http://www.k-tech.uk.com/
Old 31-Dec-2006, 13:40   #6
bike mad's Avatar
well I'm not a light weight and I do when I'm playing about pull the brake hard and to stop the forks bottoming out I need to put in a spring with a heavier spring rate,
thanks chris I'll give them a go after xmas
Old 31-Dec-2006, 18:08   #7
Simon Reed's Avatar
Mood: Cool as **** !
yes you can,usually they will come with a 9.5kg spring,you can go up or down,in half kilo intervals,you can also,say have a 9.5kg,in one leg,and a 9kg,in the other,so your average is 9.25kg,for fine tuning etc,its very common,doing this with racing !
Old 03-Jan-2007, 03:36   #8
bike mad's Avatar
well that's what I thought, you know what it's like, you what somthing but you end up knowing more than most experts, ps I ant mud slinging,
I got a rear all right, I went by the list's you have I bet but when you look at the three lists on the web thier all for the rearshock,
simon if you know better plase say, you sound like you might,
thanks
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:01.
