Old 03-Jun-2015, 21:47   #1
r15suk r15suk is offline
r15suk's Avatar
Top Yolk Removal
Hi,
If I want to remove top yolk, am I right in thinking that I don't need to remove the forks?
Just undo the fork clamp bolts, the pinch bolt at the back of the yolk and remove the steering damper. Then tap it off?
Simon
Old 03-Jun-2015, 21:49   #2
correct, helps if you can take the weight off the front end
Old 03-Jun-2015, 21:58   #3
r15suk's Avatar
Christ that was quick!!
Thanks will do.
simon
Old 17-Jun-2015, 13:25   #4
The Hammer The Hammer is offline
Bikes: 1198, 748S, 900SS, SP1, Blade, 600RR, SV650N, RG125
The Hammer's Avatar
Mood: Hungry
Works with the top yoke, too.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:25.
