Old 30-Dec-2006, 12:48   #1
apr1962 apr1962 is offline
Does a 04 999S 54mm Termi Fit a 04 999 Bip ?
I have been offered a 54mm Termi system with Titanium silencer off of a 04 999S. Will it fit my 04 999 Bip. I know I will need a power commander for the ECU, but not sure if the front pipes will fit as the 999S has a deep sump engine and 999 standard doesn't. I beleive the fairing and bracketry are the same on the 999S and 999 Bip.
Both bikes have the cast early swinging arm.
Will I notice a significant performance improvement over my 50mm part system Termi which is fitted with the Termi ECU and Air Filters?
Any help appreciated.
Andrew
Old 30-Dec-2006, 14:33   #2
khushy khushy is offline
khushy's Avatar
Riders of Bridgwater have a 54mm Titanium (end can) 999s full system on sale for £1000 in vat!
Old 30-Dec-2006, 17:34   #3
Originally Posted by apr1962
I have been offered a 54mm Termi system with Titanium silencer off of a 04 999S. Will it fit my 04 999 Bip?
Yep,the S pipe should fit the Bip.
They dont fit the other way round tho.
Old 02-Jan-2007, 09:25   #4
Nick Pavey Nick Pavey is offline
Nick Pavey's Avatar
I can confirm it does mate as that's exactly what i did.
Old 02-Jan-2007, 16:45   #5
Nick,
did it fit OK or did it need cutting etc. What did you do about the ECU?
Old 03-Jan-2007, 11:16   #6
gordonparker's Avatar
Goodmorning, if you do buy this I have a link pipe for a 999, as I discovered it will not fit an S - if you want to swop ?
Old 03-Jan-2007, 13:40   #7
Gordon I have sent a PM
Regards
Andrew
Old 09-Jan-2007, 15:10   #8
Nick Pavey's Avatar
Nick,
Fitted straight on mate. Did it myself,and i'm the least mechanical person going. Did the pipe and end can.
Have since changed some brake pads
After doing some research it seems the ecu fitting is a bit trickier,as it's right at the bottom of the engine,under the battery tray,so my dealer did it for £30 cash at my 1000 mile service.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:56.
