Old 30-Dec-2006, 21:02   #1
yorkshire pud yorkshire pud is offline
Mood: poon tang
Unhappy HELP needed. please
which is the best way to install. the opening rockers. do you install the spring with the tang inplace or put the tang under after. i am struggling at the moment. would appreciate help , as it is the first time i have done this .i know alot off you well properly able to do this with your eyes closed. i would be most grateful off any help. also hope everybody had a good xmast and wishing everybody a great new year.
Old 30-Dec-2006, 22:09   #2
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
If you can hold on a bit, I'm sure Nelly will be along soon to put you right.
Old 30-Dec-2006, 22:11   #3
Dukerob Dukerob is offline
Bikes: Diavel
Dukerob's Avatar
I think he's getting his dress ready for tomorrow night
Old 30-Dec-2006, 22:13   #4
Jon Jon is offline
Jon's Avatar
You wearing matching outfits then Rob:-)
Old 30-Dec-2006, 22:19   #5
The rocker with the spring is the closer. They aren't that easy, especially if the head is still in situ.
The easiest way, is to fit the rocker and shaft with the spring in place then lever the tang into place. Make sure you get the tang under the casting, not one of the other rocker shafts.
Access is made easier by removing the adjacent opening rocker and shaft and lowering the valve out of the way. move the piston close to to TDC to stop it falling through the head.
It's the access that makes the job difficult. The inlets are easiest, front exhaust is awkward, rear exhaust is a nightmare with the head in place.
Old 30-Dec-2006, 22:19   #6
Bikes: Diavel
Dukerob's Avatar
I thought I told you not to mention that anyway its a good job we're not going out (party at mine) we'd get mistaken for the Sugarbabes or sumat
Old 30-Dec-2006, 22:20   #7
Old 30-Dec-2006, 23:58   #8
Mood: poon tang
Talking
thanks .mate yes i meant the closer. thanks again.
Old 31-Dec-2006, 00:12   #9
Mood: poon tang
nelly am i best removing the back shock to do the the ex rockers. ave no problem doing openers just them closers. thanks for taking your time to help. have a good new year .
Old 31-Dec-2006, 14:12   #10
To be honest, if i was doing the rear exhaust, i'd take the head off!!
The access is real tight. It could take hours. It's not the shock that masks the access completely, it's the frame.
