Old 30-Dec-2006, 22:37   #1
cl0nd0n cl0nd0n is offline
cl0nd0n's Avatar
Masking for Powder Coating
For all you guys that have had frames and swing arms powder coated what did you do about masking threads, headstock plugs etc ?
Did you replace all the bearings in swingarm / swingarm pivot?
Do all seals etc need replacing after powder coating?
Old 30-Dec-2006, 22:54   #2
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
I use good old masking tape. Works fine. If I strip a bike down I always replace all bearings as a matter of course.
Old 31-Dec-2006, 12:39   #3
keefer keefer is offline
keefer's Avatar
it needs to go down to a bare frame
as you will need to have it shot or bead blasted.
I removed all the bearings from the swing arm as they would of been like grit after that
the company I used covered / masked all the important bits for me
and they used a rubber like compound to plug up all the threads before coating
so in short all bearing and seals replaced yes
Old 31-Dec-2006, 14:29   #4
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
The place I used Redditch shotblasters did all the masking for me. They used aluminum foil tape. It sticks like the perverbial and trims up with only the use of a flat blade.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:48.
