Old 01-Jan-2007, 17:55   #1
geoff m geoff m is offline
geoff m's Avatar
Mood: So its raining, your problem with that is ??
Exclamation Oil Pressure Light On !!
My oil pressure light is stuck on !! there is plenty of oil in it, and it sounds and runs perfect.
It goes out when I start the engine, then comes back on after a couple of seconds.. any ideas ?
Someone suggested it might be "wet weather related" ??
Where is the pressure sensor located ?
Thanks guys.
Geoff M
Old 01-Jan-2007, 18:00   #2
Glyn Glyn is offline
Glyn's Avatar
Mood: st2......we can rebuild
9 times out of ten it will be the sender/senser that is faulty
i've gone through a couple now
they seem to wear out quite quick and you've only got to overfill the oil a tad to knacker them
the senser is next to where you put the oil in. if you disconect the wires and look down the hole you might well even see oil in there if so it's dead. but even if you dont it would be the first thing to replace
Old 01-Jan-2007, 19:39   #3
Might be a good idea not to run the motor again until you've fixed it. It's probably a duff sensor but it might be a genuine low oil pressure problem.
Just a thought.
Old 01-Jan-2007, 20:07   #4
Just a thought.
Harbinger of Doom there!
Old 01-Jan-2007, 20:46   #5
geoff m's Avatar
oil pressure light
thanks guys,
my gut instinct says its the sender, a mate of mine had a similar problem that manifested itself when the bike was wet !!!
Considering the rain we have had recently.......(and yes, I do ride it in all weathers) will have a poke around the sensor in the morning..
thanks chaps.
Old 01-Jan-2007, 20:49   #6
ducv2 ducv2 is offline
Mine went on the blink after a good wash (might have been shock), only a couple of minutes to change.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:02.
