Old 01-Jan-2007, 20:50   #1
zhed44 zhed44 is offline
zhed44's Avatar
Mood: YELLOW!!!
Question 748 Steering Head Angle Question
Hi again,
I'd like to quicken up the steering on the 748 in a last ditch attempt to get on with the bike, so I'm thinking of changing the steering head angle from "road" to "race".
Despite what the manual says, is it safe (ie: will the bike be slap-happy)?
All other suspension settings are standard at the moment - should I change any fork or shock settings to complement or compensate for the change?
Old 01-Jan-2007, 20:53   #2
NBs996 NBs996 is offline
NBs996's Avatar
Mood: I love my 996 xxx
Hasn't caused me any problems.
Be careful bashing that castle nut round tho, those castellations are pretty soft!
Old 01-Jan-2007, 21:08   #3
Gaz 748's Avatar
Quicker to raise the rear and you can keep the steering lock
748R - Less is more !
Old 01-Jan-2007, 21:13   #4
zhed44's Avatar
Mood: YELLOW!!!
Do you mean "steering lock", as in the thing that immobilises the handlebars, or "steering lock" as in the amount of "turn" you can get, which helps you avoid hitting the opposite kerb when doing U turns?
I'd rather not raise the rear as I'm not very tall and I think the bike feels quite top heavy as it is
Thanks - and thanks to NBS too
Old 01-Jan-2007, 21:31   #5
ducv2 ducv2 is offline
You will lose the immobilising steering lock, and as mentioned, be very careful with the castellations as they are soft (as I found out). I understand that this adjustable headstock was for use with the longer race swinging arm, but I have used it on road and track for years with no worries. I also raised the ride height against reccomendations from various people, and have got the old beast to steer the way I want, though it is a bit 'tucky' on the front if you are not on the power in tightish corners. If you are worried about raising the rear, try dropping the yokes down the forks, take it easy after you have changed things, and if you dont like it you can always put it back
Old 01-Jan-2007, 21:33   #6
NBs996's Avatar
Gaz probably means both.
The key lock doesn't reach the hole with the steeper angle, and you lose a lot of turning circle - beware when you first ride it!
Old 01-Jan-2007, 23:04   #7
geoff m geoff m is offline
geoff m's Avatar
Mood: So its raining, your problem with that is ??
Talking
I had exactly the same issues, being a massive five foot seven I was loathe to raise the rear, sooooo.......dropped the forks through the yolks 1mm at a time, after three mm it steers super fast and is still well stable.
geoff M
Old 01-Jan-2007, 23:06   #8
geoff m's Avatar
just a thought, what tyres are you on ? this can also effect steering speed,I found it felt slower when I changed from bridgestone to pirelli...
Old 01-Jan-2007, 23:34   #9
zhed44's Avatar
Mood: YELLOW!!!
i'm on metz rennsports, which although they have, in a previous life been hammered by bungi, IMO steer quicker than the OE pirellis
Old 01-Jan-2007, 23:35   #10
zhed44's Avatar
Mood: YELLOW!!!
thanks for the warning.....i'll just have to perfect my doughnut technique
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:19.
