Old 23-Oct-2003, 00:47   #1
Totto Totto is offline
Altering the wheelbase!!!
Here's something i did not know ( more )
When altering the wheelbase of your 99*
Taken from
http://www.sigmaperformance.com/suspensionarticle.html
For instance if you make the swingarm 10 mm longer, as you would if you reduced the teeth on the rear the rear sprocket, you have more leverage working on the spring and therefore it gives a softer feeling. On a Ducati you would need a full half kilo heavier spring to get you back close to where you were. The best way to check that is once you get everything set up on the bike you put the bike on the ground and check the static sag, because you've got a longer wheel base all of a sudden you've got more static sag. So we add some pre-load to it to get it back to where we were. Now we test it, and the rider complains it seems to sit down a little bit at the rear, and of course the linkage angles have changed so the shocks moving slower, feels softer and with less compression. It is virtually impossible to change only one variable
Just more to think of when changing the gearing !!!!
Old 23-Oct-2003, 10:41   #2
neil748r neil748r is offline
That's the reason Monster Mob change the primary drive on Shakey's bike rather than mess around with sprocket changes.
Old 23-Oct-2003, 17:36   #3
so what can I expect if I change to 2 teeth larger at the rear
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:08.
