Old 26-Oct-2003, 00:10   #1
Eubank Eubank is offline
Knackered Clutch
Hi,
I have a 99 Duc996 Bip.
The clutch has recently stoped working - by this I mean that there is nothing in the lever.
I've replaced the master cylinder, slave cylinder, put a new line on, replaced both the bleed nipples and it worked for about 50 miles then the lever went spongy until finally I had no clutch at all.
Has anyone got any clues for me ??
Old 26-Oct-2003, 06:34   #2
Hmm,sounds like a hydraulic problem,like air in the system or a faulty piston seal in the master cylinder.I guess that there are no fluid leaks?As you have replaced most of the hydraulic items,have a look at the clutch itself.Are all the plates and pressure plate properly installed?What about the push rod that goes through the motor,its not unusual for the pressure plate bearing to seize and grind the push rod down.
Old 26-Oct-2003, 11:17   #3
Mark853 Mark853 is offline
Mood: The medication helps!
Hi Eubank,
I agree with Keefyboy if you have sorted the hydraulics you need to check the clutch.
it could also be the push rod seized in the main shaft. I have seen this before
Hope you sort it soon
Mark
Old 26-Oct-2003, 12:33   #4
Knackered Clutch
Thanks guys,
I'll strip it down this week and have a look.
Cheers.
Old 27-Oct-2003, 20:18   #5
Kanckered Clutch
Thanks Guys,
The bearing that pushes the rod from the slave cylinder to the clutch had seized!
cheers
Old 27-Oct-2003, 22:55   #6
rcgbob44's Avatar
you never get that on a Puch Maxi
Old 28-Oct-2003, 13:10   #7
thrustercat
For any future clutch issues - see:
http://ducatisportingclub.com/contro...d.php?tid=3508
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:09.
