Old 14-Jul-2005, 15:14
Roy748Bip Roy748Bip is offline
Mood: skint.....
Hydraulic clutch problems
I don’t have a problem with the weight of the clutch lever but I hate having to bleed the clutch every couple of hundred miles. The last ride i went out the lever came back to the bar but pumped up enough to disengage the drive after a frantic moment
As the slave cylinder looks original (1995 bike!) and all I’ve done to it is change the piston and seal (ongoing problem), will a new one fix the problem? Did they ever change the design, or should I buy one of those uprated units? Any suggestions would be welcome (the cheaper the better!)
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:21.
