Old 26-Oct-2003, 22:41   #1
Matthew Smith
Carbon Velocity Stacks...
Flicking through the DP Catalogue, noticed carbon velocity stacks!
Does anyone have them, have read some where you need a diffrent chip for set up?
Any information/comment...
Or are these the ultimate stealth wealth pose factor...
Old 27-Oct-2003, 07:38   #2
ben998 ben998 is offline
Mood: Spring is coming, but its a bit
Unless they are a different profile that the oe plastic ones I cant see the need for rechipping?
Actually, I don't really the see the point at all to be honest. Are they going to add any benefit - doubt it - and you wont even see them!
Personally I wouldnt bother - Id spend the cash on something else
Ben
Old 27-Oct-2003, 08:54   #3
Felix Felix is offline
They are the bellmouths inside the airbox.
Old 27-Oct-2003, 09:00   #4
rcgbob44's Avatar
Your joking weeksy!!!!!!!!!!!!!
Your level of technical/mechanical knowlege astounds me!
Still thats wot the clubs for, init!
Old 27-Oct-2003, 09:41   #5
rcgbob44's Avatar
Just so.
Old 27-Oct-2003, 10:15   #6
DSC Member antonye antonye is online now
Aren't the stacks aluminium and not plastic? I doubt that there would be much in terms of weight saving compared to carbon ones...
Old 27-Oct-2003, 10:18   #7
Dibble
Weeksy,
I didnt know what they were either ....!!!
Old 27-Oct-2003, 11:48   #8
rcgbob44's Avatar
The Titanic also had them but they were of the chimney variety!!!!!!!
Old 27-Oct-2003, 17:18   #9
neil748r neil748r is offline
The carbon velocity stacks are really for use on a race bike and they are actually a different length/profile to the OEM stacks. Altering the length of the inlet track is an old trick for shifting the power curve. The carbon ones are designed to give max power high up the RPM range at the cost of losing some low down grunt so probably not ideal for a road bike. That's also the reason why you (usually) have to re-chip after fitting them.
[Edited on 27-10-2003 by neil748r]
Old 27-Oct-2003, 19:20   #10
Rushjob Rushjob is offline
Rushjob's Avatar
Mood: :-)
Funny this should come up, look what I saw on eBay tonight......
http://cgi.ebay.co.uk/ws/eBayISAPI.d...tegory=10 448
If you're after some.......
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:58.
