Old 02-Nov-2003, 17:44   #1
Sb13471 Sb13471 is offline
Will 996r wheels fit my 748??
Hi all,
Have been offered some marchesinis apparently from a 996r, and was wondering if these wil fit my 748 without any problems??
can anyone help??
Old 02-Nov-2003, 17:53   #2
Jasper Jasper is offline
Jasper's Avatar
Yes.My ally ones were straight of a 996R.
Old 02-Nov-2003, 19:01   #3
changing wheels
Ok, thanks Jasper.
Am i right in thinking that these are slightly wider rims? The rear being 6' instead of 5.5'??
Will i still be ok with the same width rear tyre, or will i have to go up a size?
Old 02-Nov-2003, 19:22   #4
Jasper's Avatar
You can stick with the 180/55 with no problems.
Old 02-Nov-2003, 20:39   #5
Bj.O.rn Bj.O.rn is offline
Front discs may need to be swapped.. (different offset maybe..)
(not shure if the 996R has the same front brake setup as the '01 748R, if so you have to do the swap)
[Edited on 2-11-2003 by Bj.O.rn]
Old 02-Nov-2003, 21:35   #6
Front discs may well be a differnt offset. I'm pretty sure you can use your own discs or if needed, have some spacers turned up to "offset" the calipers to compensate.
I think the R uses a 5.5" rear rim anyhow?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:10.
