Old 11-Dec-2015, 22:15   #1
podkin99 podkin99 is offline
podkin99's Avatar
touring screen / bar rissers
Hi every one i have just brought a st4 after having to amit i am old an the 916 may be is not be the right bike to go touring on to the WDW and i love it but i was thinking of changing the screen for a touring one of some kind ,any coments good or bad would be great also i seen bar risers on a site in the usa just ones which lift the standard bars up and back .There are 12mm ones and 25mm ones ,but i read some coments that with the 25mm ones when you turn all the cables go tight your advise would be super to pod.
Old 12-Dec-2015, 00:15   #2
Hello Pod!
Ive been to WDW twice on my ST4s now and the bike was always much better than I was!
Ive still not found a screen I'm 100% happy with - I have the Ducati touring upper fairing and screen now & I only rate it as average.
Standard screen with a Laminar Lip http://www.laminarlip.com/ is the most comfy Ive tried but a hi-rise screen can work well, I like http://www.zerogravity-racing.com/
Here are some bar risers from a great guy in Ireland:
http://www.ebay.co.uk/itm/DUCATI-BAR...-/262142775469
So you can fit 50mm clip ons.
or you can fit riser plates under your existing clipons.
Ive raised my bars a CRAZY amount, careful cable routing and longer brake hoses are needed the only problem at the 75mm extra height I have is that the choke cable cannot work - a longer cable might work but, Ive not sussed that out yet...
