Old 04-Nov-2003, 17:18   #1
itacud itacud is offline
U-Tool
Can anyone recommend a way of undoing cylinder nuts without having to purchase the £170 ducati U-Tool?
Or where I can get one for about £50?
Old 04-Nov-2003, 17:59   #2
you can use a crowfoot spanner on you wrench. Not the "perfect" way, but it does work OK.
My first tool was a spanner with a 1/2" socket welded in the center, then an allowance made on the torque setting for the extra leverage.
Old 05-Nov-2003, 14:42   #3
Many thanks Nelly. Have ordered some.
What sort of compensation did you give for torque using the crowsfoot spanner.
Old 05-Nov-2003, 15:19   #4
On the crowfoot, it's negliagble. The ones I have are 25mm from drive centre to stud/nut centre so that's 2.5%. Thats within the tolerance of 5% that Ducati specify, so I'd set the wrench exactly and tighten it up as normal.
the spanner I used to use, with the socket welded in the centre was about 100mm centre to centre so that was a different story
Old 13-Nov-2003, 10:10   #5
Thanks Nelly, But what make of crowsfoot did you use?
I still can't manage to get the ratchet over the crowsfoot to turn the nut. Looks like I'll have to weld a bar to it...
Old 14-Nov-2003, 21:13   #6
Here's an inexpensive clever design using a socket welded to a box-open end wrench.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:38.
