Old 04-Nov-2003, 20:49   #1
Totto Totto is offline
Can you guess what it is ?
Well can you ?????????????
Hint " It fits all 99* models !!"
Ps its not a std part !!!!!!!!!!!!!!!!!
[Edited on 4-11-2003 by Totto]
Old 04-Nov-2003, 21:18   #2
Felix Felix is offline
Broken sidestand bolt?
Old 04-Nov-2003, 22:58   #3
rcgbob44's Avatar
A MkIII dipthrong wobulator that fits the double rotating frou frou valve on the double overhead underhand models!
Old 04-Nov-2003, 23:13   #4
fatduke11111's Avatar
A Harley piston?
Old 04-Nov-2003, 23:43   #5
Desmondo Desmondo is offline
Mood: :devil:
A home made frame plug?
Old 05-Nov-2003, 00:09   #6
Nope
But it is home made , you can just see the very fine pin sticking out at dead centre !
I got fed up trying to measure the rear ride height to the centre of the wheel spindle , so now you just pop this in & put the steel rule on the pin to get centre , makes things a bit simpler
Old 05-Nov-2003, 00:10   #7
The nut behind the handlebars - LOL
Old 05-Nov-2003, 01:25   #8
Got a couple very similar, have marked the centre point but OD is 40 mm so just measure from there and add 20mm.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:11.
