Old 06-Nov-2003, 20:06
the phantom pieman's Avatar
the phantom pieman the phantom pieman is offline
Mood: Sort of shuffling along .....
Changing the front sprocket
yeah, yeah, yeah, I know I can do a search, however ......
Aboout a year ago I decided to go 14t on the front, and bought a sprocket from Forza Italia for the ole 998S.
I was told they were all standard thru out the range.
Anyway, my old sprocket has a lock washer on it, and what FI sold me has spines and obviously a position for some sort of locking plate .....
Can i use what I have got with the standard lock washer, or do I need a 998 specific sprocket?
And do you have to do all the farting around with the clutch thingies that the haynes manual for a 996 says, or again is a 998S diff.....
Thanks !!!
Old 06-Nov-2003, 21:42
Nigel C's Avatar
Nigel C Nigel C is offline
Mood: happy bike passed MOT
my replacement sprocket (genuine part) had splines on it i think they should all be the same did you get a new locking washer when you bought it ? should be a black one as the old gold coloured ones were replaced by black ones (different design i think ).
took mine off without removing the clutch slave cylinder as per manual i think that is if you remove the sprocket with the chain in situ
Old 12-Nov-2003, 12:46
ben998 ben998 is offline
Mood: Spring is coming, but its a bit
Is it worth replacing just the front sprocket with a 14T, or is it best to change the rear as well? My 998 is used for road riding with the occasional track day thrown in for good measure.
cheers,
Ben
Old 12-Nov-2003, 12:54
Dukerob's Avatar
Dukerob Dukerob is offline
Bikes: Diavel
have a chat with Nelly at Cornerspeed, he keep sprockets and retainers etc in stock and will tell you all about the benefits/disadvantages of the 14T front. I've seen him play with some real low gearing but he's back to something more 'normal' now.
There's no need to change the rear.
Tel: 01623 758877
Old 17-Nov-2003, 12:48
swiss 998s swiss 998s is offline
PP
They are the same, I got sent a 996 front sprocket and had the same question, it fitted no problem
Rob
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 03:20.
