Old 08-Nov-2003, 17:53   #1
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Tachos
Can anyone tell me the diameter of the Tacho on the M600/750/900 up to 99 or the M600/750 frrom 00.
Thanks,
Rob
Old 09-Nov-2003, 08:17   #2
Monsters up to '99 did not have rev counters as standard.From '99 onwards (i.e models) they came with a new rev counter/speedo console.I'll nip out later and measure the clocks on the missus's M900i.e.
Old 09-Nov-2003, 10:09   #3
Rob B's Avatar
Thanks,
The reason for the post is I'm looking for an 80mm tacho and the DP cat lists two for the range of bikes as listed
Old 09-Nov-2003, 17:57   #4
Ok,the bike is a M900ie and the tach measures 80mm across the bezel and 93mm to the outside of the bezel.It looks similar to DP part no.96502100A.The differances are the lettering (just says Ducati across the face) and its got an oil warning light inside.
The later Monster tacho's look similar again but have a little window in the bottom for a digital display.
Hope that helps.
Old 09-Nov-2003, 18:08   #5
Rob B's Avatar
Thanks for that..
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:20.
