Old 14-Nov-2003, 12:12   #1
DC DC is offline
DC's Avatar
Mood: Double 9, Single 6.
Oil cooler???
Hi,
Just wanted some advice regarding fitting an oil cooler to my 748 now that its making more power.
i am assuming that the 916/996 one will fit as i have seen the standard mounting holes on the front cylinder head are the same.
Is it just a case of fitting the cooler and oils lines etc. Or do i need other parts as well?
All advice would be very helpfull.
Thanks.
Old 14-Nov-2003, 12:39   #2
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
If the engine has never had one as standard I am guessing that you'll need to find out what Ducati do to force oil around the cooler circuit. On older suzukis there is a plug in the oil way that is removed if you don't have a cooler.
One of the engine gurus will be able to confirm this.
Rgds, Rob
Old 14-Nov-2003, 13:27   #3
RickyX RickyX is offline
RickyX's Avatar
You need to fit a spring plate between the oil filter and the crankcase.
Have a look on a parts microfiche for a 748SP/9*6 and you'll see it.
Of course, that is in addition to the cooler/hoses etc.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:19.
