Old 20-Nov-2003, 07:49   #1
ben998 ben998 is offline
Mood: Spring is coming, but its a bit
749/999 clocks on a 998?
Whilst riding in to work this morning I was suddenly struck by the thought that if the 998 has the same testastretta engine as the 999, is the wiring loom similar, and if so, would it be a relatively easy (but certainly not inexpensive ) job to fit 749/999 clocks to a 998?
Anyone any ideas? Just wondering, thats all...
cheers,
Ben
Old 20-Nov-2003, 08:06   #2
Felix Felix is offline
Don't think so. As far as I know, they clocks on the 999 connect to the ECU via Can-Bus, which is a communications protocol originally developed by Bosch. The wiring will be completely incompatible. It is essentially a single wire that transmits all the data, as opposed to individual wires on the 998, etc.
Borrow someone's wiring diagram from the 999 and compare it to yours.
Old 20-Nov-2003, 08:11   #3
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Yep, I think this is right, Ducati are starting to exploit some of the technology resident in the MM ECUs.
I expect you could do it but you'd have to swap the whole loom and dash. I expect (from experience) that one or two of the sensors may be differenent too.
Rgds,
Rob
Old 20-Nov-2003, 08:13   #4
everton
My understanding............and I'm not that technical when it comes to bike mechanics/electrics................is that although the engine is much the same that is really the only similarity between the 998 & 999 Testastretta models.
Essentially though, design features & components for the 998 rely on the heritage of the 916/996/998 base design.
The 999 is a total redesign of just about everything and as Felix says certainly the clock wiring design is totally different.....sorry.
The clock and related instrumentation on the 999 is brilliant though!!
Old 20-Nov-2003, 09:39   #5
Speedo Drive springs to mind
