Old 22-Nov-2003, 09:07   #1
Aotearoa Aotearoa is offline
Mood: Xstatic
intermitant hard starting
Get ya think caps on boys!
Have had the ST4s up and running for about 2 months now has been running really strong except twice now when i hve been riding i have stopped and started a few times then all of a sudden when i go to start it , it will crank fire then die and just crank over ...the first time i left it for a couple of minutes then tried again no luck , after doing this for 3 -4 times it fired and i just held it wide open reving to about 7thousand and it stayed running.
today though it just would fire so i held it wide open and cranked it for about 40 seconds and she fired.
I pulled the fuel pump out and checked for split fuel hoses but all was good as was the fuel filter....???????????
HELP!
Cheers mark
Old 24-Nov-2003, 13:00   #2
Monty's Avatar
Could be the fuel pump relay Mark, it's under the seat by the tool carrier box. There are 2 relays and the fueling relay is the left hand one-at least it is on my '4S. You won't like the other alternative which is a ECU fault, that's what my problems turned out to be in the end.
How's it back home in NZ, weather nice and warm?
John
Old 24-Nov-2003, 13:18   #3
Daft question perhaps but how do you know the fuel filter was good?
Old 24-Nov-2003, 13:18   #4
Old 24-Nov-2003, 13:18   #5
Old 24-Nov-2003, 15:45   #6
Rushjob Rushjob is offline
Rushjob's Avatar
Mood: :-)
Heard you the first time Paul!!
Old 24-Nov-2003, 21:14   #7
Dam computers!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 00:46.
