Old 02-Dec-2003, 07:24   #1
uncle porry uncle porry is offline
uncle porry's Avatar
rear shock set up....help !
my rear shock (showa-748bip) seems a bit "slack" i can grab the spring with my hand and move the whole shock from side to side, i think it needs to be adjusted, looked in the manual and saw that there are three ways to adjust, do i have to adjust these in a particular order or do i just tighten them all up ???
thanks
Old 02-Dec-2003, 07:40   #2
ben998 ben998 is offline
Mood: Spring is coming, but its a bit
What are the three methods of adjusting in the manual you are referring to? If you are referring to compression, rebound and preload, then no, dont just tighten them all up! I cant think of anything else it says in the manual about adjusting the rear shock?
I dont think that the rear shock should really move from side to side, but the whole unit can be rotated slightly if you try and twist the reservoir, but its not a significant amount. How much can you move your shock?
Have you checked the top and bottom mounting points to make sure that they are correctly tightened and haven't worked loose?
Old 02-Dec-2003, 17:10   #3
Nigel C Nigel C is offline
Nigel C's Avatar
Mood: happy bike passed MOT
If it's anything like mine you won't be able to adjust the collar and adjuster on the top cos it's a: stuck solid
b: you can't get a decent purchase on the thing cos the wheel/frame/exhaust get in the way .
c: if you get hold of it you have about an inch of space to work with
and d: skinned knuckles to go with it as well
Old 02-Dec-2003, 22:45   #4
Dibble
uncle porry,
the best value for money expenditure you will ever incur would be to get the suspension set up properly by an expert ....
I paid £70 to have the front & rear sorted and it completely transformed the bike ...
Old 03-Dec-2003, 21:51   #5
sounds like a good idea to me dibble.....
Old 03-Dec-2003, 22:34   #6
paulmort paulmort is offline
Mood: Blooo Duke gets red heads
porry
I paid 30 notes at a trackday to a guy who attends some of them, advertised as Shockwave. Best money ever spent. Dont know if he advertises on the web, but worth a look. Based in SE england somewhere
If I find his URL, I'll send it via u2u or post it on the board
rgds
mort
Old 03-Dec-2003, 23:29   #7
Mood: aving a laff
For base settings you could try MH Racing?
They advertise in the monthly's and opnbly charge four quid for set up info to work from.
