Old 28-May-2003, 22:59   #1
keggsey keggsey is offline
Mood: Spiffing
Front forks
My front forks have more rings showing above the top yoke on one side than the other, should these be the same and if not what problems can it cause or perhaps more importantly could it be hiding?
When I ride the bike and then free wheel without holding the handle bars the bike tracks straight not do I feel any pulling to one side or the other.
Old 28-May-2003, 23:23   #2
Any settings on the front forks should be identical for both legs.
I would set everything back to the standard settings and make any adjustments from there.
The difference in rings means that one fork leg is being preloaded more than the other.
I've just read your post again and seen that it's the rings above the top yoke your talkin' about!!!!!
That means that the fork legs aren't aligned correctly in the yokes.
You really need to get it looked at/sorted mate. Either the front end has been put back together incorrectly or the leg isn't being clamped by the yokes properly and is slipping.
If you pulled the axle out, the legs wouldn't line up!!
[Edited on 28-5-2003 by nelly]
Old 29-May-2003, 00:15   #3
Totto Totto is offline
My fork legs (998) were out 3mm from NEW !!!
Old 29-May-2003, 09:24   #4
You should get this sorted - toute suite!!
This can't be good!
If the bike's new, get it back to the dealers and get them to sort it.
Also, get them to check that the rebound and compression are set evenly too!
Tim
[Edited on 29-5-2003 by Rattler]
Old 29-May-2003, 17:37   #5
Guido's Avatar
And get them to send a note to the factory and say this ain't good enough for a reputable firm to be dishing out and demand an explanation.
Things like this cause accidents and after hearing today's news, we've had enough of those..
Sorry, but I'm still gutted DJ is no longer with us...
Old 30-May-2003, 13:13   #6
Mood: Spiffing
Wish it was new, 95 model so a little more worried, something might be out Got its MOT next week so will ask the garage to have a look.
Thanks for the comments
Old 03-Jun-2003, 19:30   #7
Mood: Spiffing
Well passed MOT no probs.
Found out my silly mistake.
I was looking at both fork legs from one side and the rings are not parrallel to the yoke so that there are 4 rings on the outside and 3 on the inside. When looking at both from the outside the rings showing are the same. Doh!!!!
Old 04-Jun-2003, 04:57   #8
I done the same !
But mine were out !
Old 04-Jun-2003, 11:42   #9
KJ KJ is offline
Mood: Direct - Fiesty - Controversial
WARNING WARNING WARNING!!!!!
to those of you not really familiar with removing/securing fork legs and top yokes beware of the correct torque settings.
You will have to check - but I am 99.99999% certain that even though its a feking big diameter the torque settings for the triple (big bottom) clamps are only - 15nm and the top yoke is only 10nm!!
Please check first!!!
KJ
Old 04-Jun-2003, 14:26   #10
Guido's Avatar
That'll explain why my forks travelled 2 inches thru the yolks, popped the top yoke clean off and sent the steering damper sky-rocketing through the windscreen during my last off-road excursion.
Thankfully I had done the ejector seat impression.....All in the best possible taste mind you..!!
Valid point though Khush. Might help avoid this type of occurrence.....
[Edited on 4-6-2003 by Guido]
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:49.
