Old 17-Jan-2004, 20:06   #1
Disk weights - a comparison!
I've been a bit bored today, so decided to weigh some disks!!!!
I'm trying to get the best wheel/disk combination and had a few disks "lying" around, so I though a comparison may be interesting, as the lighter you can get unsprung weight, the better!!!
I compared a single front disk off of a 916 (I think) a single disk off of a 996R and a single Braking "Wavey" disk.
The Brembo 916 disk is circa 1999 I think and weighed 1.85kg.
The standard, alloy centred, disk off my 996R weighed in at 1.3kg.
With the Wavey disk weighing in at 1.375kg.
You can work out all of the differences / percentages etc if you want.
So although there's only 75 grammes difference (x2 for both sides), I'll probably stick with the waveys as they do perform better and look better than the standard 996R disks.
If you've got the standard Brembos - you're giving up a lot of weight advantage if you've not got the later "alloy" ones or Waveys fitted.
The weight differences may not sound alot, but its all about gyroscopic forces and the heavier the front wheel / tyre / disk setup the slower the bike will turn.
If you can get the bike to turn quicker, you can go faster and turn later into a bend and also pick the bike up faster to get on the gas earlier! This can save seconds a lap!!
The 996R and Wavey disks aren't cheap though, with a pair of either costing around the £330 mark.
Worth it? If it can reduce your lap times its gotta be good.
I can post some pics of the different ones, if anyones anal enough (as I am) to want to see them.
Tim
Old 17-Jan-2004, 20:14   #2
muttsnuts muttsnuts is offline
muttsnuts's Avatar
Mood: Feeling Sad being Ducati-less :(
you are bored aren't you !! - I mean, I am at work bored, but your at home and could be out riding/boozing etc, etc, but what do you do - weigh disks ! !!!! :P
Old 17-Jan-2004, 20:20   #3
chris_of_1979 chris_of_1979 is offline
Mood: I'm Bad!
Would be interesting to see how the cast-iron floating brembo's weigh up to those.
Been thinking of swapping the ones on mine to waveys for a while now.
Old 17-Jan-2004, 22:30   #4
I wouldn't have thought that it was a good "scientific" measurement in terms of gyroscopic effect... don't forget that a weight further from the centre would cause more gyroscopic effect than the same weight closer to the centre...
The design of the wavey disks may mean that although they weigh slightly more, they actually produce less gyroscopic force on the wheel...
...or something
Old 17-Jan-2004, 22:40   #5
Yep........
Dave........If only the kids would look after themselves eh!!!!
Anthony - Fair point, but it was the comparison between the older and newer type brembos that is the greatest difference!!
Tim
Old 17-Jan-2004, 22:56   #6
Chris,
The Brembo ductile iron full-floating rotors weigh 1.71Kg each.
Old 18-Jan-2004, 13:23   #7
muttsnuts's Avatar
Tim, give them one of your bikes to play with that should keep the quiet for a while - especially if you give them the keys as well !!
Old 18-Jan-2004, 14:23   #8
Unsrung weight is important though. The disks, wheels etc are not supported by the suspension so any weight you can loose here gives the suspension an easier time.
Old 18-Jan-2004, 16:04   #9
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
Tim !
Old 18-Jan-2004, 18:21   #10
Jon!!!!
.........I know, I know!!!!
These are your disks, I promise.
Just show me the money!!!!
Tim
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:34.
