Old 22-Jan-2004, 07:26   #1
crm250 crm250 is offline
crm250's Avatar
Mood: Firing on all 4 !!
Dim headlamp - 916
Right, headlamp is still naf, and when riding after a while it comes bright. the brightness doesnt go up and down with revs, but just by itself when riding (perhaps over bumps)
Am pretty sure this is down to a poor contact somewhere as the bike charges well and is putting out normal voltage and all elecs work fine.
Any tips on where to start looking ?? or is it a case of strip the bike, remove most of the loom and clean and reconnect ?
Cheers all
Old 22-Jan-2004, 11:03   #2
Check the voltage with a multimeter and you may also want to hook it up to an ammeter as well to measure the current draw. This will (probably) tell you if it's a duff circuit.
Have you tried adjust the alignment of the headlight using the (6mm?) allen bolt at the front? You may find this helps.
Also, try fitting some "brighter" bulbs in it. I put Halfords own-brand "blue" bulbs in mine and the light is definitely whiter and makes the beam more noticeable. I've heard good reports about their "20% Brighter" (or whatever %-age it is) own-brand range as well.
Old 22-Jan-2004, 13:10   #3
Totto Totto is offline
Used Halfords "Xenon" 20% brighter bulbs !!!, found then much better than the std ones !
Old 22-Jan-2004, 14:51   #4
Check first to see if you have the same problem on both the high and low beam. If the problem is only on low beam, I'd first suspect the the 12V or earth connection to the bulb - or the bulb itself.
If you have the same problem with the high beam, I'd first check the battery connections and work my way forward checking common in-line connectors.
Old 27-Jan-2004, 22:24   #5
crm250's Avatar
High beam is rather bright in comparison.
But you are right, as the thing flickers brighter every now and again, i suspect a poor earth or duff connection.
I will be stripping the lights out and putting a meter across to see the voltage and how it compares to the battery.
Next will be the switch itself, maybe a clean of the contacts.
Failing that - a new bulb and try to demist the inside of the lamp itself (looks like a big bowl of fog inside there)
Tis funny though, it has only done this since the following on a recent trip
riding with lights on - no revcounter and temp guage off the scale, also no indicators or horn or headlamp.
Turn off lights, and rev counter and temp came back - still no indicators or headlamp
Never found the problem as i just lifted the seat unit give it all a wiggle (technical term - for fooked about with stuff i have no idea about) and it all came back !!!
Put money it's all related though
It also charges well, so can rule out the rectifier
Old 29-Jan-2004, 11:14   #6
Sounds like a faulty earth somewhere along the line. It may even be a slightly loose connector in that viper's nest of wires tucked behind the headlight!
Old 30-Jan-2004, 23:33   #7
Robbie Robbie is offline
Mood: Variable
That's a question I've been meaning to ask !
How do I demist or clean the inside of my helmet glass ? I haven't investigated the unit yet. Can you split the glass from the reflector ?
Old 31-Jan-2004, 01:16   #8
Yes, you can get at the unit inside!
If you remove the headlamp unit from the bike and turn it round, you'll see that on both sides you can unscrew and unbolt the back to get inside at the lens.
However - leave it indoors overnight and it demists itself!
Old 31-Jan-2004, 02:08   #9
You just need to use a glass cleaner. The film is actually an initial outgassing of the heated plastic parts. The same film collects on the inside glass surfaces of a new car when it sits in the sun.
Old 31-Jan-2004, 23:00   #10
crm250's Avatar
Found the problem, The clip that holds the low beam bulb in had bust in half, hence the earthing on that bulb was not only poor but also a corroded mess.
A new clip, clean of the headlamps, new Xenon bulbs and i reckon it should make nightime travel less fraught with excitement. (it was like riding with a tinted visor at night)
I also think it may be time to strip all the bodywork off the bike, and clean and inspect each connector on the loom. This should buy me another 12 months of hassle free electrics (yeah i wish !)
Thanks guys
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:33.
