Old 30-May-2003, 10:08   #1
YLO998 YLO998 is offline
998 Biposta suspension settings
For a 14.5 stone rider , without leathers! what would be suitable fast road suspension settings. All of these free mag givaways never list the 998 bp!
thanks in advance
Phil
Old 30-May-2003, 13:58   #2
Totto Totto is offline
First start with the Static sag !!
I have 30mm front ,10mm rear , get this sorted then post back if its any better !
I have a softer rear spring on my 998 BP but you should be ok as i am 13stone kitted up !
Old 30-May-2003, 14:45   #3
Felix Felix is offline
Agree with Totto. Make sure the static sag front and rear are sorted first. It the basic starting point.
Old 30-May-2003, 21:22   #4
Yep,I agree with Totto and Felix,get the sag sorted first.
For 998 bip settings,do a search on the old message board.Henners had his bike set up as part of a MCN feature.
Old 03-Jun-2003, 09:16   #5
BOLT BOLT is offline
Mood: Waiting for the Sunshine
Yep - have to agree with Totto, but as well as suspension, also worth considering tyres and pressures.
Swapping the original Pirelli's for 207RR's made my 998 turn in much quicker - made the bike much easier to ride at speed.
Old 03-Jun-2003, 09:30   #6
Good point Bolt prob best check the trye pressure's first
I just found this out the hard way , went out for a ride & thought the bike & started playing with the fork settings , after a couple of adjustments the bike felt no better , checked the tyre pressure to find the front 6 PSI down !
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:55.
