Old 23-Jan-2004, 23:37   #1
custard custard is offline
Mood: yes mistress
sprockets
Please can someone tell me what the standard number of teeth there are on a 1999 748 bp (front and rear)
Old 23-Jan-2004, 23:42   #2
Richard, On the BP model it should be 14 front, 38 rear
Old 24-Jan-2004, 10:21   #3
Correct go to the top of the class
Chris.
Old 24-Jan-2004, 10:39   #4
altough I find 40 rear has helped keep up with the BIG boys!
Old 24-Jan-2004, 11:48   #5
I have a TSS rear carrier, going to get a 41 tooth to go on it while at the Aly Pali next week
Chris.
Old 24-Jan-2004, 14:57   #6
Got myself a TSS rear carier with a 38 and a 40, both from Scatman at http://www.ducati-shed.com/
The front is a 14 tooth on all 748 models, along with a 520 chain at 94 links in length.
I believe you don't need to add any links upto 41 on the rear, but if someone can confirm that would be great!
Old 24-Jan-2004, 15:56   #7
You need to add two links. Here's a guide:
Sprocket separation values above are essentially changes to wheelbase caused by the change in sprocket diameters.
Remember to take a ride height reading first and then reset it after changing your sprockets and/or chain.
[Edited on 1-24-2004 by Shazaam!]
Old 24-Jan-2004, 16:26   #8
Cheers Shazam.
Chris.
[Edited on 24-1-2004 by chris.p]
Old 24-Jan-2004, 18:52   #9
Shazaam your the man !!!
When increasing the rear sprocket size I always recommend trying to add links and run the rear wheel as far rearwards as you can.
