Ducati Sporting Club Message Board
Home Calendar Gallery Membership Online Shop Extras
Go Back   Ducati Sporting Club Message Board > Archived > Y2007 Archives
Forum Forum Rules Register FAQ Search Forum Today's Posts Mark Forums Read
DSC Track Attack 2010 - The Pictures!
Pictures from the DSC Track Attack 2010 at Cadwell Park are now available to view and order online from
Cope Images
Ordering details can be found on the website. Click the link for more details!
More...
Old 30-Jul-2007, 07:52 PM
Shandy's Avatar
Shandy Shandy is offline
Mood: Getting me coat.....
Exclamation Broken Spring Do-Da......
Following my off ive started stripping down the 916 and all seemed well with the engine, no significant metal bits in the oil etc, until i took the flywheel side casing off. There's a spring thing on the gear change linkage which seems to have snapped, with a bit lying in the bottom of the engine casing as below in the pics,
The spring do-da,
the bit that broke off,
Now what do you all think, was this a result of the off or is it a known problem that can happen?? Either way what else will i need to check to be sure nothing else is damaged in the area??
I'm just happy the little bit didn't make it into anything moving
Cheers in advance,
Shandy
Old 30-Jul-2007, 08:20 PM
jeff st4s's Avatar
jeff st4s jeff st4s is offline
Mood: Looking for a one way ticket to the 'Ring.
http://www.ducatisportingclub.com/sh...ad.php?t=50749
If you look at Fordie's thread you will see that spring and where it goes in one of his photos, hope that helps.
Old 30-Jul-2007, 08:35 PM
Fordie's Avatar
DSC Region Organiser Fordie Fordie is offline
Regional Organiser - BHCN
Mood: Raring to Ride
This might help although it with the flywheel removed
Old 30-Jul-2007, 08:44 PM
Shandy's Avatar
Thanks fella's, although 4D's thread has given me another worry, id been getting a strange noise from that side of the engine for a little while too, ah well something else to check
Cheers,
Shandy
Old 31-Jul-2007, 09:26 AM
DSC Member nelly nelly is offline
The spring isn't a common problem, but they do break. Not an expensive fix as they are available seperately.
Watch the alignment of the selector arm when you refit it though.
.....but better in YELLOW, or Bloo and now even RED
www.cornerspeed.co.uk you know you want to
http://www.nolimitstrackdays.com the best trackday organisers in the UK
Old 31-Jul-2007, 01:19 PM
Shandy's Avatar
Thanks nelly, it's been added on the i need parts list
Old 31-Jul-2007, 02:38 PM
If ya struggle to get one, I have stock
Forum Jump
Powered by vBulletin Version 3.5.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© Ducati Sporting Club
