Old 31-Jan-2004, 20:04   #1
Mr Nick Mr Nick is offline
Sticky Stuff...
Can anybody recommend a brand of double sided sticky tape that is suitable for use on carbon bits and bobs?
I've got a key guard that I want to refit to my bike but the old sticky bits are beyond reasonable service but all the tapes I've come across have been too lightweight or to thick.
Old 31-Jan-2004, 21:30   #2
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
Nick, you can always try mirror sticky tabs or double sided carpet tape.
Old 31-Jan-2004, 21:51   #3
Felix Felix is offline
Oridnary silikone sealant works a treat.
Old 31-Jan-2004, 23:48   #4
Hadn't thought of silicon sealant - that's a really good idea!
A couple of blobs of hot glue works a treat for me and it doesn't pull the paint off with it either!
It also goes really flat too, so you won't get a gap like you do with sticky pads.
Old 31-Jan-2004, 23:53   #5
I've tried the carpet tape - B&Qs own brand though and it was bobbins. Tried sticky pads and they were to thick and left a gap between the carbon and the tank. I was after something like the stuff you get on tank protectors but I may have a stab at the silicone. I guess it comes off easy enough if it all goes tits up??
Old 01-Feb-2004, 09:48   #6
Clear Silicon Sealant every time, easy to put on, little or no raised edges, unlike sticky tabs, easy to position when putting on, easy removel of excess silicon & when you want to remove ir, easy to get off & clean up.
Chris.
Old 01-Feb-2004, 12:28   #7
Dazza Dazza is offline
Mood: Rossi-tastico!
What do you clean silicone sealant off with, from paintwork, with out damaginng the paintwork then?
chhers.
Old 01-Feb-2004, 15:37   #8
Mark853 Mark853 is offline
Mood: The medication helps!
will be difficult, i use silicone but only on things you never want to get off again e.g. a carbon tank pad. It does work well though.
Old 01-Feb-2004, 16:27   #9
chris.p says its easy to get off...
Old 01-Feb-2004, 20:46   #10
I used black silicone sealer. Coat the item you are mounting even and attach it in place .
i then used lengths of masking tape to pull it to where it needed to be. When this sets you can clean up the edge with your thumb nail etc
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:31.
