Old 02-Feb-2004, 14:00   #1
TopiToo TopiToo is offline
Bikes: 748ish . .
Mood: Sampai jumpa lagi
removing a breather valve
Hello,
any ideas which tool to use? I am trying to remove an anodised breather from a 748bp, which has small holes around the base. It stuck fast . .
regards
TopiToo
Old 02-Feb-2004, 14:54   #2
Scottch Scottch is offline
Mood: Is it summer yet?
Dynamite or Nitro always work for me mate!
Sorry, I know the thingamybob you mean but I've never taken one off. I had thought it was just a press fit?
Cheers!
Scott
Old 02-Feb-2004, 15:34   #3
Angle grinder?
Old 02-Feb-2004, 15:49   #4
John W John W is offline
John W's Avatar
Apparently they screw in.
I think the holes are not to remove it with, but to take it apart. Could be wrong though.
Best bet is to use a belt clamp (like used for oil filters or by old people to open jam jars )
hth.
Cheers,
John.
Old 02-Feb-2004, 16:08   #5
neil748r neil748r is offline
TopiToo,
The holes around the side are indeed to remove the breather from the engine.
What you need is a "hook spanner". I got mine from Farnell. Here's a link to the tool you need: http://uk.farnell.com/jsp/catalog/vi...?prodId=225254.
Only problem is you need a minimum order of £10 before VAT. I just got some TV remote control sized batteries to bump it up over the £10 mark.
Hope this helps,
Neil
Old 03-Feb-2004, 00:23   #6
Nigel Booker Nigel Booker is offline
Bikes: Ducati 996R and MV Agusta F4 1000R
Nigel Booker's Avatar
You could find that the breather is in pretty securely, most after market versions recommend using a sealing compound such as silicone.
Old 03-Feb-2004, 09:33   #7
Bikes: 748ish . .
Hello,
Well thanyou for the constructive and not so advice, I think I will pass on the Dynamite, it's the breather I need off not the garage roof
I will try a belt clamp first, and yes I put it on using compound in the first place . . .
never leaked oil though . . . .
regards
TopiToo
Old 08-Feb-2004, 00:09   #8
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
TT I put mine on with the same rubber O ring that was off the std one. Hasn't leaked yet. I had it on my other bike and to get it off, I just persuaded it with a softwood timber dowl
[Edited on 7-2-2004 by Jon]
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:11.
