Old 12-Feb-2004, 07:44   #1
ben998 ben998 is offline
Mood: Spring is coming, but its a bit
998 Sump plug size?
Does anyone know what size Hex key (Allen key - whatever ) fits the sump plug on a 998?
Im hoping to get the key on the way home so I can do an oil change as my set isn't large enough. Also, whats the torque setting when doing it back up?
cheers,
Ben
Old 12-Feb-2004, 20:22   #2
Mike Davis Mike Davis is offline
Mood: Shiney
10mm Allen key socket and 42nm torque.
If you are doing an oil change the oil pick up mesh should also be cleaned on alternate changes this is also 42nm torque
:P
Old 12-Feb-2004, 20:47   #3
Dont forget to get some new alloy washers for the sump plug and the strainer (different sizes!!)
Old 12-Feb-2004, 20:55   #4
Robbie Robbie is offline
Mood: Variable
On the subject of sump plugs the one on my 748 parts pile (used to be a bike) is well chewed. Allen key twists out with minimal force .
Does anyone have any clever ideas about it's removal without drilling & filling the sump with swarf ?
It's exactly the same as the one on my Paso but it, however, has been well looked after.
Old 13-Feb-2004, 08:39   #5
Mood: Shiney
If it has been done up to the correct torque or near, then a dot punch on the edge of the flange tap with a hammer and this should be enough to dislodge it and get it out.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:19.
