Old 31-May-2003, 23:28
Dropping forks through yokes.....
To quicken-up the steering???
Has anyone had a go at this???
If so, by how much please???????
2mm????
5mm???????????????????????????
Regards - Frustrated Frank and clumsy Clifford (The big Red Dog).
Old 01-Jun-2003, 09:51
psychlist's Avatar
Mood: Lucky? For some, maybe!
Spoke to quite a few bods about quickening the steering and teh most favoured response is jack up the rear end. By lowering the front you lose ground clearance and run the risk of grounding the fairing lower if not your pegs.
On the 900ss I think you can adjust the rear ride height without increasing your spring compression, so it wont make it harder on yer backside?
Old 01-Jun-2003, 11:56
Julian Julian is offline
When I bought my 900ss, it had been successfully raced, and as such the forks are through the yokes by about 20mm. When it was raced there had been a steering damper fitted, but in the 5 years that I have had the bike, I have had no problems with head shake.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:47.
