Old 16-Feb-2004, 15:23   #1
ben998 ben998 is offline
Mood: Spring is coming, but its a bit
748/916/99* petrol tank compatability
Does anyone know if the same petrol tank is used across the 748/916/99* range?
Im assuming that the 998 fuel pump may be different (just a guess) but will a tank from an earlier bike fit my 998?
cheers,
Ben 998
Old 16-Feb-2004, 16:17   #2
Agree with Weeksy...
....its the early 748/916 bikes that use the banjo type connections.
I'm not sure when the connectors changed, but as long as the tank is off a post '99 bike you'll be fine I reckon.
Tim
Old 18-Feb-2004, 07:57   #3
Ivan 996S Ivan 996S is offline
i disagree with weeksy. My first 748sp had the same connectors as what are fitted to my 996s
Old 18-Feb-2004, 13:50   #4
DAVE HARRIS DAVE HARRIS is offline
Check with a dealer first but I seem to remember that the part number for the tank was the same for all748/916/996/998 verions, the plate in the bottom of the tank is a seperate item
dave
Old 18-Feb-2004, 14:22   #5
Dave - you\'re right!
I'm sure that the tanks are the same across the range, its the pumps (obviosly removeable) that the connectors vary on.
I'm also pretty sure that both pump types will fit all tanks.
Tim
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:19.
