Old 19-Feb-2004, 19:12   #1
DJ Tera DJ Tera is offline
Understeer?
Not sure how to describe it, but since fitting the rennsports the bike seems to "fight" the lean - past a certain lean angle (not very much) it just doesnt want to lean, a bit like having the pillion lean the other way, and if i push the outer slightly the bike stands up almost instantly, does anyone have any ideas?
Old 20-Feb-2004, 08:38   #2
DSC Member Karl Karl is offline
Karl's Avatar
Have you checked your tyre presures, what are they at now?
Old 20-Feb-2004, 08:57   #3
stumpy1 stumpy1 is offline
stumpy1's Avatar
Mood: http://www.knightroadraceteam.co.uk
yep, i would check what your tyres pressure are...and are they second hand tyres.....if they are, they might be more worn on one side....
[Edited on 20-2-2004 by R1-ian]
Old 20-Feb-2004, 09:48   #4
My bike was the opposite when i changed to D208's. I found i was putting in way to much steering effort, probably to compensate for the worn tyres. Initially flet like i was riding on a knife edge. did all the usual checks but there was nothing wrong. They just felt different and it took some getting used to.
Old 20-Feb-2004, 10:13   #5
I thought it might be tyre pressures too, especially since the problem isn't quite as bad when the tyres are warmer - weird thing is it didnt feel this bad when I did a session at brands with less than 15 psi in the front
Old 20-Feb-2004, 11:15   #6
may be worth checking the headraces, also try removing the damper and see how it feel, not that I would recomend doing that over the fast bumps of Combe
Old 20-Feb-2004, 11:55   #7
Garry Smith Garry Smith is offline
Mood: Up For It!
Hi,
Personally having used Rennsports/Supercorsa's etc. my preference for track based riding are Dunlop 208 GP's, significantly faster turn in, good grip levels and a really nice feel, very communicative. Haven't used them on the road, so they might feel a bit too 'nervous' for road use.
Old 20-Feb-2004, 12:18   #8
I wish mine felt nervous! The day after i fitted them i nearly came a cropper on my fave roundabout, turned it in, bike wouldnt lean anymore, went straight towards the kerb!
Yesterday, rode down to the bottom of my road and took a right, the same happened again
The reason I chose renns/SCs is because they offer the rear in a 190/55 which gives the quick steering of a 180 coupled with a bigger contact patch
Old 20-Feb-2004, 12:45   #9
Whele Whele is offline
Mood: Meditating
I'm a bit confused by this remark
"The rear in a 190/55 gives the quick steering of a 180 coupled with a bigger contact patch"
A far as I'm aware a 180 steers much quicker than a 190.... or am I missing something?
[Edited on 20-2-2004 by Whele]
Old 20-Feb-2004, 13:03   #10
dickieducati's Avatar
correct me if im wrong but a 180/55 steers quicker than a 190/50 predominantly because of it higher profile ie 99mm compared to 95 for a 190/50.
now a 190/55 will have a profile of 104.5 so it should steer quicker and also offer a greater contact patch. obviously tyre weight will have an impact too.
for whats its worth the 190/55 should ideally be on a 6 inch rim, not a 5.5 .
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:05.
