Old 14-Jul-2018, 17:43   #1
khushy khushy is offline
khushy's Avatar
WANTED - techtronics quickshifter - race pattern
After 13 years of faultless service my Techtronics Quickshifter has packed up :-(
Just wondered if anyone had a complete setup they wanted to see before I drop a load of dosh on a new one - reverse pattern gears
Khushy
Old 15-Jul-2018, 12:11   #2
khushy's Avatar
just the lever
its actually just the lever that is pooped - doesnt even have to be complete as its the switch that not working
Old 24-Jul-2018, 19:51   #3
khushy's Avatar
all sorted now - managed to locate and purchase a new reverse pattern, control lever with adjustable microswitch from the guys at BikeSports Developments - £500 cheaper than a new fancy, strain gauge actuated quickshifter system - once I fix the old lever - I will add it to the FOR SALE section if anyone needs it!
Old 26-Jul-2018, 19:37   #4
I haven't seen a microswitch lever for sale for some time as most went to the strain gauge type some time ago
I did see a old mechanical pull type brake switch connected to a reverse pattern lever via a spring on a 748 the other day, was plugged directly into the PC3 USB without any anti bounce circuitry in line, apparently it worked suprisingly well
