Old 26-Feb-2004, 19:08   #1
jim flynn jim flynn is offline
Mood: Mellow Yellow
Clip on bars
Went for an MOT today and failed on my bars. They are Renthal clip ons that have been on for a couple of years and gone through a few MOTs already. Admittedly on full lock the foam around my clocks is deformed and you can't use any of the switches, but the tank isn't fouled and I can still hold onto the bars.
Have I just gone to a jobs worth tester? Has anyone else fitted clip ons and found a way to avoid this problem?
Will I be better off just fitting the original high bars again?
What would happen to the geometry of the bike if i dropped through the forks and fitted the clip ons above the top yoke?
Cheers,
Jim
Old 04-Mar-2004, 06:59   #2
iceneweb iceneweb is offline
Mood: i'm hungry
what about if you wind out the steering stop screws so that the bars don't hit the foam?
Old 06-Mar-2004, 19:33   #3
Mood: Mellow Yellow
Need more space between the tank and bars as well on full lock so only half a fix. Have decided to refit the originals and see how low I can mount them without fouling anything.
Old 12-Mar-2004, 22:27   #4
Mood: Mellow Yellow
Had a brain fart and thought about the stop screws again. Tried winding them in all the way but no joy, then thought about trying some bolts I had lying around. Found a couple of longer ones that fit and they seem to do the job. Now to try the MOT again!
Old 13-Mar-2004, 18:36   #5
Job done ???
A tip I remember to make the steering stop a little 'softer' is to screw some plastic tyre dust caps onto the bolt ends.
I had a few split on me and it can be fiddly but it does feel nicer
Frank
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:11.
