Old 26-Feb-2004, 21:38   #1
mit1 mit1 is offline
998 power commander
hello everybody im new here and enjoying what i see in your forums,i am hoping one or two of you knowledgable people can tell me if a 998s power commander will fit on my 748s,i am thinking rightly or wrongly that the pc111 is standard to 748-998 its only the software that is on it that is specific to model and can be changed by downloading another program on it?hope someone can help,thanks in anticipation.
Old 26-Feb-2004, 22:34   #2
does the 748S run the 5.9M ECU on the side of the battery tray ot the 1.6M unit under the seat, if it runs the 5.9M the same as the 998S does then I would think it would only be a matter of loading a different map.
Welcome to the forum
Old 26-Feb-2004, 22:50   #3
The part numbers are different for the bikes running the 1.6M (748-996) ECU and the bikes running the 5.9M (998/ST4S/S4) ECU.
Think it'll be down to more than just maps. Probably different connectors for the later ECU bikes.
Give Dynojet a ring. Check Dynojet for more info.
Old 27-Feb-2004, 02:08   #4
neil748r neil748r is offline
The short answer is yes!
Have a look at my recent post http://ducatisportingclub.com/contro...d.php?tid=6457. Feel free to give me a call (number's in that post) and I'll answer any questions you may have on PCs.
Cheers,
Neil.
Old 27-Feb-2004, 17:44   #5
thanks for your replies,nelly you were right, there is more to it than just downloading a new map onto it, dynojet said they were genericaly different and would not work, so thanks for that.
neil mite be in touch for one of those but need to count the pennys first,the reason i asked the question was because there is one for sale on ebay,2days left to bid,said to be brand new and its only on for £41 at the moment sounds good if you have a998s-r .
thanks again
Old 27-Feb-2004, 19:49   #6
Don't tell everyone, I'vebeen bidding on it from day 1
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:37.
