Old 27-Feb-2004, 18:31   #1
Jasper Jasper is offline
Jasper's Avatar
PC CRASHED!HELP PLEASE!!
Hi guys,
just gone to boot up the pc.Won't even load windows.Hangs in DOS saying"verifying dmi pool data"Won't boot from floppy,hard drive or cd rom.Can only get into the bios.I'm running xp prof.Any help is MOST WELCOME!!
Old 27-Feb-2004, 18:45   #2
Eamonn Eamonn is offline
Mood: Corners like a Lego man
It's not getting to the Windows software bit yet, so it looks as if there's a problem with memory, hard disk or mother board.
If you've recently put in new memory, check its seated properly. Check cables going to the hard drives are correctly in place.
Resetting the BIOS may be an option, there's usually a small jumper pin on the mother board that resets the system back to its factory state - where it is depends on the type of motherboard you have.
Hope that's of some (!) help.
Old 28-Feb-2004, 10:06   #3
Guido's Avatar
Rich,
My experience tells me that if anything strange occurs with your PC and you haven't changed any hardware/software yourself recently then it's normally virus or spyware related.
Have you and can you run a virus boot disk?
Let me know if you haven't got AV software cos I may be able to help you out.
Good luck.
Gc
Old 28-Feb-2004, 10:18   #4
Jasper's Avatar
Looks like the Hard Drive has gone down.BUGGER!
Old 28-Feb-2004, 20:41   #5
If your hard drive has gone m8 that would not stop you booting to floppy or CD. If you can get into the Bios settings, you can change the boot order. If it is set to Hard Disk first, thats probally why you can not boot to Floppy or CD. Might be worth booting to floppy even if your hard disc is down, as you may be able to get to some data depending on how your drive is formated. There is a resuce CD that Sysinternals do that will boot to Windows PE to allow you get the data off or repair. Quite a few options still left for you depending on how bad you want that data. Let me know if I can help anymore.
Old 29-Feb-2004, 00:08   #6
Jasper's Avatar
have e-mailed you
Old 02-Mar-2004, 19:26   #7
Jasper, I mailed you but it has just bounced back. Is your mailbox full ??
Anyhow all it was is take a look at this:
http://www.computerhope.com/issues/ch000474.htm
Old 02-Mar-2004, 20:18   #8
Jasper's Avatar
Hi thanks for that.No my mail box isn't full.Don't know why it bounced back:
Jasper@dragonland.plus.com
it is a bit long winded to explain here!Trying to figure out wether it is hardware or software at the moment!
Old 02-Mar-2004, 21:38   #9
Totto Totto is offline
Operator Error :P
Don't forget to rule that one out !
Old 02-Mar-2004, 22:51   #10
Jasper's Avatar
It was all those effin files you sent me!My Pc only worked in English!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:47.
