Old 29-Feb-2004, 06:10   #1
hk999 hk999 is offline
Slight engine oil leakage
I have done 3000km on my 999. Recently, I could see some very minor engine oil leakage. Is it normal?
Old 29-Feb-2004, 06:28   #2
I have known some rocker boxes and the crankcase breather to weep oil after a hard ride.
Old 29-Feb-2004, 09:56   #3
I didn't ride that hard...reved to 7,000rpm usually.
and...i wonder if its a common problem and if i need to do something to the engine in long-run.
Old 29-Feb-2004, 19:42   #4
dave w dave w is offline
dave w's Avatar
Mood: My K5 Rocks !!!!
Mine had a small weap on the rear cylinder rocker cover..... Cure nip up rocker bolts X6.... Problem solved.:P
Old 29-Feb-2004, 19:47   #5
Triple Nine Triple Nine is offline
Mood: Very happy with the Multi
6K miles and not a drop, but then I only tour on mine
Old 01-Mar-2004, 09:27   #6
thanks guys.
the technical support here in Hong Kong isn't that great as the market size is too size to justify a significant franchise. Anyhow, I will check with one close friend here who used to work for Ducati in the UK.
Cheers~
Alex
Old 08-Mar-2004, 18:08   #7
Dave, what do you mean x6? 6 bolts? I have similar situation on the rear rocker and I guess its due to similar situation. Am I supposed to tighten them up (btw, I have only seen 4 bolts on the top cover) to a specific force rate as the manual doesnt really say so.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:56.
