Old 26-Nov-2007, 21:43
countcoupe countcoupe is offline
Mood: Allreet
Buying 900 ss advice
Hi Team,
Sorry if posting in wrong section. I am interested in buying a 1993 900 ss. Could anyone give advice before I buy. i.e. what questions should I be asking.
Cheers, Count.
Old 26-Nov-2007, 22:57
Welcome to the Site.
Superb choice of machine sire - I have a 1992/3 900ss, below I'll edit a post by a contributor called Shazaam! that is actually intended for Suberbikes...916, 996 etc
But I'll take out the stuff that does not apply and try to find some more specific 'SS' data:
"BUYING A USED DUCATI SUPERBIKE
As with any used motorcycle, your best approach is to find a bike with a well-documentated service history and have the bike inspected by a Ducati-trained mechanic.
A motorcycle that uses the same oil to lubricate the engine and gearbox loses viscosity more quickly and therefore needs oil changes more frequently than an automobile. So look for a service history showing oil changed at 2,000 mile intervals.
The maintenance schedule is thoroughly covered in the Owner's and Service manuals that haven’t changed much over the years. The Owner's Manuals for the 2000 to 2003 model year bikes are available for download at:
http://www.ducati.com/bikes/manuals.jhtml
Here are the questions you need to ask the previous owner and your mechanic.
Has the alternator wiring been inspected and replaced?
The wiring and in-line connectors between the alternator and the regulator/rectifier (on all model years) overheat because they have to pass over 30 amps continuously. The solution is to replace the wires with a larger gauge and eliminate the in-line connectors. Do it before you have problems.
When was the last time the cam timing belts were replaced?
It's critical that the cam belts be replaced every 12,000 miles to avoid potentially catastrophic engine damage. Ducati uses smaller diameter pulleys that cause the belt to turn tighter corners than the larger pulleys used in automobile engines. Ducati also uses a small diameter back-side belt-tensioning idler pulley arrangement that causes the belt to flex back in the opposite direction on each revolution. This back-and-forth belt flexing promotes premature fatigue failure. The original drive belt material often failed before the first recommended 6,000 mile replacement interval so Ducati now uses a Kevlar fiber reinforced belt.
Have the fuel lines been replaced? (not esp for SS but still relavent)
Ducati fuel injection uses a high pressure fuel pump and in-tank fuel line failures are common if the recommendation to replace fuel hoses every two years is not followed. Further, a partially clogged fuel filter will disrupt fuel flow, cause bad throttle response, and can lean out the motor on the fuel injected models. In particular, it will present excessive back pressure to the fuel pump which increases electrical current demands thereby making the charging system work harder which commonly leads to a regulator/rectifier failure.
When was the last time the fuel filter was replaced?
A clogged fuel filter causes the high pressure fuel pump to draw much higher currents that are prime contributors to regulator failures.
Has the connection to the starter motor been inspected?
The rubber boot that covers the connection to the starter motor catches and holds water that corrodes the terminal making it crank hard or fail to start. Cover the connection with dielectric grease and check it seasonally.
Be Aware ...
The following are some design deficiencies and common problems that you should also be aware of:
In-Line Fuses. There's been reports of corrosion developing at connections at in-line fuses causing a high resistance to develop that overheats the wiring and fuse holder causing a partial meltdown and/or loss of continuity. The engine management relay fuses (one 15A, one 15A and one 20A, or one 5A and one 20A fuse depending on the model and year) located underneath the seat. Failure can cause your bike to stop running without warning. A clue is that the fuel pump will not run when you turn on the ignition and toggle the handlebar switch to RUN. The 30A fuse (or 40A on later models) between the regulator/rectifier and the battery. Failure can prevent charging and eventually drain the battery during a long ride. A clue is that the charge warning light (pre-1999 models) will come on.
Starter Relay Connection. The electrical connector that goes to the starter relay is often a poor fit and can cause inability to start for no apparent reason. Zip-tie it tight.
Flywheel Retaining Nut. Problems develop when this retaining nut is removed. They may loosen and cause extensive damage and they are difficult to re-install reliably.
Cush Drive. These occasionally are reported to back-out and cause damage to the swingarm.
Oil Pressure Sending Unit. These parts are unreliable. However, if your oil pressure light comes on don't run the engine until you diagnose the problem.
Low Fuel Sending Unit. This part is unreliable. Get in the habit of resetting your odometer when refueling.
Clutch Slave Leaks. Watch your reservoir fluid level. There are after-market replacements for the stock unit that are more reliable. Also, 2001 models were recalled for attention to a clutch slave cylinder problem. These slave cylinders would hydraulically lock the clutch if they leaked. Ducati has stocked its dealers with replacement cylinders.
After You’ve Bought
OK, you've just bought a Ducati so what do you need to know? What do you need to do?
Well, first you'll need to know where to find accurate and complete information, sources of in-depth experience, and even sources of informed opinion. This may, or may not, include the personnel at your local Ducati dealer.
Then you need to fully grasp the bike's maintenance requirements and the nasty consequences of ignoring them. And so, you'll also need to be aware of common problems and their solutions. Some are mentioned above.
Third, you'll need to understand how to balance the benefits of modifying your bike against any reduction in reliability and ride-ability. That is, learn the reasons why Ducati engineers made certain performance trade-offs and understand why adding race-bike components is not always the best solution for a street-bike. In particular, keep good records. They'll help you backtrack when you get lost, be of help in resolving warranty disputes, and be valuable to you when you sell your bike.
Finally, you'll probably need to adjust your suspension to suit your weight and riding style.
Information Sources
Ducati's official web site contains product information, technical articles, parts lists, and manuals.
Buy a Haynes Service & Repair Manual for your bike, even if you don't plan on making repairs yourself. I guarantee that you'll refer to it regularly and it'll save its price many times over. Ducati dealers also sell a shop manual containing similar information at a premium price.
http://www.haynes.co.uk/inc/keywords.asp?keyword=Ducati
Diving into a complex, expensive motorcycle with a screwdriver, a wrench, a snippet of impressive-sounding advice off the internet or from your neighborhood garage mechanic, and no manual, is a very risky business, especially if you want to avoid warranty issues.
Authorized Dealers
Your local Ducati dealer has to make money to stay in business, so if you don't support them they won't be around when you need them. Most dealers sell and install the line of Ducati Performance and other vendor's after-market parts and accessories. They're not deceptive, but try to understand where they're coming from when they offer advice.
Ducati Specialists
Bike owners are fortunate when they live near a Ducati specialist's shop since some owners ship their bikes cross-country to take advantage of their expertise. Accessories can be bolt-on affairs but proper balanced engine performance modifications require years of first-hand product development, testing and tuning experience. In particular, suspension component selection and tuning is both an art and science. If you have special needs for the track or street, these people can help.
John Hackett Performance
204 Keresley Road
Coventry, UK
CV6 2JJ
Tel: +44 (0)24 7633 5300
Internet Forums and Email Lists
As you become familiar with your bike and you spend some time on the internet you'll see many instances where someone asks for help and gets incomplete and somewhat inaccurate advice. You really don't know whether the response to your question is from a real expert with technical training, an experienced rider with suspension savvy, a hands-on guy who's done it all, or just a well-meaning guy just repeating something he's heard.
If it's opinion you're after, internet forums speak volumes. It's great fun to watch or join the banter over the best tires, spark plugs, motor oil, suspension settings, air filters, and more. It's the only way to sort out complex issues and share your experiences. But, it's hard to sort-out opinion from fact when your looking at a two or three sentence answer.
There are de facto experts on these forums who spend a great deal of time helping others in need but they don't answer every posted question. They offer-up their knowledge and experience freely, but like most people, they're disinclined to offer extensive explanations to someone who doesn’t read the Owner’s Manual, or hesitates to spend the money on a shop manual, but want to pick everyone's brain with how-to do-it type queries. Something about helping those who are willing to help themselves is the logic behind that. It's pretty easy to tell when someone hasn't read the owners or shop manual by the nature of the question.
The following forums and mail list are Ducati-specific. Don't forget to use the search function.
The Ducati Index
http://www.cowin-tech.com/ducati/
Club Desmo
http://www.clubdesmo.com/
Ducati Sporting Club
http://www.ducatisportingclub.com/
Ducati Message Boards
http://speedzilla.zeroforum.com/zeromain
Then there's Ducati Online/The Ducati List. It's a Ducati-related e-mailing list that can generate scores of e-mails to your in-box a day, although you can also subscribe to a condensed version. There is also a list of answers to frequently asked questions (FAQ's) on-line.
http://www.ducati.net/
Performance Improvement
The biggest performance boost to a Ducati comes from rider improvement. Handling is truly awesome in stock trim, so a riding school and track time will pay huge dividends here.
A sure way to improve handling performance is to reduce weight. Ducatis are not as lightweight as current Japanese machines but weight reduction is easy albeit expensive. After you remove any extraneous equipment (tool kit, reflectors, etc.) and have switched to a lightweight battery, it then requires an expensive diet of magnesium wheels and swingarm, carbon fairings, fuel tank, and titanium nuts & bolts etc. (the sky's the limit here.) But take care not to reduce weight at the sacrifice of safety, reliability, and normal maintenance and inspection requirements. For example, too much flywheel and clutch weight reduction and you give up drivability and traction exiting corners in order to gain acceleration.
For increased acceleration it's much cheaper to increase horsepower than it is to reduce weight. Every seven pounds of weight reduction is about equal to one horsepower from a physics point-of view.
Higher compression pistons, increased displacement, fuel system changes, port work, cams, valves, crank work, rods, and full exhaust systems all are effective ways to increase horsepower, but pushed to the limit, engine life and service costs suffer.
The idea is to try to build a balanced package based on how you'll really ride the bike - a hard thing to do for many of us, myself included. Start off by making sure that the stock machine is properly tuned and adjusted. This often can make a stock Ducati much faster for very little money.
Suspension Settings
Let me say it up front. The factory recommended suspension settings will give you the best OVERALL handling. Period.
The factory settings won't provide the most comfortable ride nor will they always result in the fastest track times because any set of suspension settings is a compromise and the stock setup is no exception. The suspension settings were developed by Ducati's test riders to give them the best handling characteristics over the widest possible range of riding conditions, so they are not necessarily the optimum settings for your favorite road or your personal riding technique.
Nevertheless there are some initial adjustments you may need to make. Also, one point bears mentioning up front. It is important in any suspension work, to keep a record of the starting point settings and all changes to avoid later confusion regarding the effects of each change.
Initial Setup (only general info wrt 'SS')
Ducati often makes two versions of their bikes. Monoposto (single seat) Ducatis have a softer rear spring in them as standard because they are not capable of carrying two people. Biposto (two seat) models have a stiffer spring installed to allow the bike to occasionally carry a passenger, when you temporarily increase the spring pre-load.
Ducati monopostos, as delivered, are set-up for a rider in the weight range of 65-75 kg (143-165 lbs.) If your weight (including gear) is significantly outside this range, you'll want to replace your springs with a more (or less) stiff unit to allow you to adjust the suspension correctly to suit your own weight. If you're heavy and you ride a biposto you'll probably still be OK but a lightweight on a biposto will definitely need a softer spring.
If your weight with gear on the bike is 200 lbs. or more, even if you've set your static pre-load properly, the stock spring probably isn't stiff enough to keep the rear end from bottoming out unless you crank up the compression damping.
To pre-load the stock spring for this heavier weight you'll need to compress it so much that you've reduced its effective range of motion. The higher pre-load needed for a heavier rider's weight will also cause the rear to top-out more readily requiring you to increase rebound damping to slow it down.
Too much rear spring pre-load will also cause your bike to ride higher in the rear. A higher rear end (or lower front) will give the front forks a steeper angle. This then results in a tendency of the bike to over-steer, where the rear wheel looses traction first so the rear end breaks loose.
The idea here is that you need to let the spring (not the dampers) control the range of motion of the suspension. Too-stiff damping causes handling problems over bumpy road surfaces. Handling is enhanced when the dampers are set soft enough to control the wheel movement, allowing the tyres to track the bumps rather than skip over them. Track surfaces are smoother so higher pre-loads and damping of a taut suspension are less of a problem.
It's important that in beginning any suspension setup that the spring pre-loads should be adjusted first (including correct determination of required spring rates.) It's also important to note that all of this should be done before any adjustment of damping rates, or steering head angle.
You need to set the front and rear spring sag amount for your own weight plus gear and a half tank of gas. The way this is done is by measuring the suspension change with you on the bike sitting in the riding position, leaning forward with enough weight from your hands on the handlebars to mimic your riding at speed. See your bike's service manual for the procedure for setting the bike's spring pre-load and measuring sag. Again, buy a Haynes or Ducati manual, you'll need it.
After setting the pre-load on the correct springs, you can then go on to adjust the suspension's rebound and compression damping.
Also, if you make any sprocket changes, then make sure you've reset the ride height by changing the length of the tie-rod adjuster. On superbike models any size changes to the final drive sprockets or chain length will usually require an adjustment of the rear axle eccentric hub that, in turn, affects your rear ride height and wheelbase - and your handling.
Finally, you should probably avoid using suspension settings developed by other riders, specifically motorcycle magazine test riders who commonly tweak each new bike's suspension settings in an attempt to improve on factory settings, and then publish the results. These settings may actually be an improvement for one particular rider on one particular track but the factory settings are still the best overall comfort-performance trade-off for the average rider on an average road.
For example, a review of a dozen magazine tests of Ducati superbike compression and rebound damper settings showed that even though there is a wide variation between riders, their settings average-out to the factory recommended settings. So it looks like Ducati knows its business.
Cheers - Frank
Old 26-Nov-2007, 23:03
Purple Worm's Avatar
Purple Worm Purple Worm is offline
Mood: Looking for fun
I think I need to read all this a couple of times to get it all in .
Still you can't say this site doesn't help
I've picked up some good advice from this post alone
Old 26-Nov-2007, 23:16
A nice bit more from our friends at www.ducati.net:
900SS tips and tricks (1991-1998)
submitted by Archie Rodriguez
This post was sent to the list by Arch, our grand master when it comes to this model. It's the best post I've seen on this subject so I am using it here in as it was posted to the list: Re: '91~'98 SSs... First of all, if given the choice, buyers should choose an SP over a CR simply because the former comes with truly useful upgrades. Problem things to watch for are few. Common stuff (like early problematic head studs) are mostly weeded out by now. (BTW, I think the upgraded ones are dark, not the other way around. Could be wrong though as it's been a while since I've thought of it and mine has FbF studs anyway.) While the vast majority of frames remain crack-free, some have seen cracks near the steering head as can be seen on my site. Check for that. Same thing for the swingarms. Some have shown cracks near the pinch bolts at the pivot. This was fairly common early on and was caused by overtightening of the pinch bolts. (The manual only calls for 34 to 37 Nm. Using the proper torque value, my '91's original aluminum swingarm remains intact despite the bike's extensive mods and increased output.) Also, really early ones had soft valve guides. A relatively inexpensive fix and most folks waited till they truly need replacing. It can vary too, my '91 model's originals were fine as of 17k miles way back when the engine went through its big build-up and they were replaced by performance pieces at that time. Regardless, all of that's likely weeded by now as well.
Here are some useful SS resources...
http://www.ducatitech.com/2v/index.htm
http://www.duc.org/900ss+report.htm
http://arch.home.texas.net/ss/history.html (My little old SS.)http://www.ducatitech.com/2v/sp_cr_faq.html (SS vs CR differences.)
http://www.ca-cycleworks.com/shop/ca...cati/elec.html (See an Electrex regulator.)
And some Ducati-specific online marketplaces to monitor... http://www.ducati.net/classifieds/ http://www.clubdesmo.com/discus/messages/5/5.html http://www.amasuperbike.com/classifi...at&catToShow=a http://www.cowin-tech.com/ducati/Cla...t&CountHit=Yes
Good luck in your search, Chris. There are some sweet ones out there as most folks discard things that aren't latest & greatest. A real shame. I'm a big fan of the 2V Duck motor and '91~'98 Supersports in particular. Theses little scoots are great fun to own and fiddle with. They respond well to time honored tweaks including even the simple ones. A mechanical canvas. They're keepers. Have been for many years now... :-) Arch
arch@texas.net
Old 26-Nov-2007, 23:39
I'm trying to think back through all my own experiences but I think most of them have been summarised above but here goes for things I'd specifically check on an SS I was going to buy....
Service history.
Wheel and Steering head bearings.
Front and Rear suspension. (leaks, travel and quality)
Frame (steering head) and swingarm (pinch bolt area) cracks
Discs - float and disc thickness / scoring.
Hear the bike being started....slow to crank? (poss battery / starter probs)
'excessive' engine noise? - (very subjective this one - esp when new to Dukes)
Possible extra checks...
Voltage regulator
Fuel tank internals + tank prone to rubbing at the back from the seat.
Generator wiring - LHS of engine; bullet connectors can be rubbish.
I'm sure I'll add as I go along !!!!
NB - many threads I've read say the FE (and Superlights) are a better buy than a std SS - unless you really want the pillion option and dont want to retro-fit a pillion seat.
Old 27-Nov-2007, 00:14
Mood: Allreet
Wow, Thankyou so much for the great info.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:13.
