Old 02-Jun-2003, 14:15   #1
rocket rocket is offline
Bearings
does any one know the number which is on the front bearings got to order some and i need the number
Old 02-Jun-2003, 15:03   #2
Guido's Avatar
Rocket,
The MY2002 748 Parts catalogue states it as being
75162.2566
That shows the 3-spoke brembo wheels. You might want to check if you have 5-spoke Marchy's, but I can't see them being that much different.
Old 02-Jun-2003, 15:56   #3
The actual bearing number against that part number is a 6005-2RS.
Might be able to source them from an engineering supplier?
Drop the wheel to double check. You should be able to spot the ID on the outer race.
Or check the wheel bore and axle.
Bearing dims are 47mm x 25mm x 12mm
Old 02-Jun-2003, 18:37   #4
cheers lads
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:59.
