Alarms and Related Security
Old 04-Mar-2004, 13:24   #1
webbyc webbyc is offline
webbyc's Avatar
Datatool Alarm Sensitivity - HELP!!!
Anybody who has seen my new bike or stood near it will know how sensitive the alarm is. It even goes off in a strong wind!!! (And that's not from my curry on a saturday night). How do you adjust the sensitivity? I'm gettin fed up with keep having to turn it off.
Also can you lengthen the length of time before it switches itself on? It feels like seconds at the moment.
Old 04-Mar-2004, 17:08   #2
I guess you have the System 3 alarm fitted??
If you do then the movement sensor is fitted inside the alarm casing itself.
There is no adjustment as such, but you can reduce it by backing off the mounting screws a little. If the unit is screwed down too tight then the sensitivity will be feather touch, as you are finding.
If the unit has been cable tied to your bike, cut the ties, put some foam between the alarm and the mounting point and re tie.
Not very technical, I know, but that is the "approved" method
There is no time limit as such before the alarm goes off. Light movements will trigger a "warning". 50 of these little beeps and the thing goes off.
If there is a big movement, it'll go straight into siren. If the sensitivity is as light as you suggest, you would get many of the warnings.
A way around it, rather than a solution though, is to drop it in "ferry mode" for general parking purposes. Press the oval/triangle button, once the unit has armed and it'll disable the movement sensor. The bike will still be immobalised and protected from hot wiring etc.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:30.
