DesmoDue Bikes For Sale & Wanted
This section is for DesmoDue Bikes that are both For Sale and Wanted.
Old 26-Feb-2019, 15:47   #1
Lee M Lee M is offline
Bikes: Fire-blade, Monster 600
Lee M's Avatar
Mood: Living the dream!!!
A Class 620SS
For sale: - whole set up. Contact me for pictures
Fellow DD'ERS, it's with a heavy heart that I have decided to pack up racing. My whole set up is for sale.
I am booked in and paid for Brands Hatch (all three days), if someone buys the lot they can have my entry and I will deliver everything to them at Brands. I will even set it up for them. If not I will race (attend) at Brands and split it up. Total package £5000 ovno inc Brands hatch test day and two race days free.
Ducati 620SS with V5, ready to race, 620cc 6 speed engine approx 4000 miles from new and never raced. APTC slipper clutch, engine refreshed, valves re-shimmed, new oil and filter, new timing belts and valve timing dialled in. New brake pads front and rear. The engine has foam air filters, an Andy Pike clutch slave cyl. Frame repaired and braced near head stock - see photo.
The bike has ST4 forks with 916 internals and serviced by Kev before Xmas, Nitron rear shock serviced by Nitron before Xmas, both shocks set up for a 15 ½ stone rider.
Aluminium swinging arm, 2 into 1 exhaust with titanium stubby can running at about 100 – 105 Db, 8 litre fuel tank, external fuel pump and crankcase chain protector. This bike and spare set of wheels with wets £2100 ovno.
Spare engine:- 620SS 5 speed engine, APTC slipper clutch, top end engine refreshed 2017 by Ghosty, two new valves, valves re-shimmed, valve timing dialled in. Barnet race springs and race friction/steel plates. Only raced for 1 full season. It has a small oil weep at the rear cylinder like most engines. £500 ovno.
Spares: - 1 x front wheels inc discs with wet tyre, 1 x rear wheel inc disc with test day tyre, 1 x set of new race tyres, external fuel pump, 620 throttle position sensor, clip ons, front and rear brake pads, ignition coils, leads and HT caps. Throttle cable, 2 x engine casings, 2 x front discs, top & bottom yoke, 2 x screens, 620 standard clutch complete, oil cooler, 2 x oil filters, piston rings, 7 x aluminium sprockets, 3 x sprocket carriers, 3 x rear sets, air filters, Crank position sensor. 1 x set of front brake discs. Body work from last season, 2 x nose cone brackets, full fairing, damaged seat unit and 4 x glass fibre moulds. Specialist tools:- Haynes manual, Ducati factory manual, timing belt tensioner, cylinder head spanners (two sizes), 620 clutch holding grips for standard clutch, magnetic mount, 2 x DTI, steel plates, 2 x dummy shim tools, engine turning tool and 2 x dial guages. £550 ovno
Van.
Ex St Johns ambulance, so you do not pay road tax or toll bridges/tunnels. Renault master T35 (2.8 turbo diesel) 1999 184371 miles, runs really well, had new alternator belts and idler pulley last year. It is 5 speed and has 3 seats, darkened windows and blinds, fully insulated. Had a 3.5 meter Fiamma F45s wind out awning with 2 x storm braces, 2 ring gas hob, it has a fold up single bed but can easily be made into a double (I have the materials), 7 kg gas bottle, a two ring gas hob and toaster, pumped drinking water, 2 x leisure batteries, two new tyres last year. It has pneumatic suspension, the back drops down and you pull out a ramp for easy loading. You can fit two motorbikes in the back. It has a small oil weep from the engine. MOT on 24th April, I can renew the MOT if req. £2000 ovno.
Forgot to say it has a Webasto 12v diesel heater in the back!
Old 01-Mar-2019, 21:04   #2
martin.tomkins martin.tomkins is offline
Newbie
Bikes: ducati 600
Spare parts
Hi would you consider selling some parts individually Cheers martin
Old 01-Mar-2019, 21:13   #3
Lee M's Avatar
Hi Martin,
I will do, if it doesn't sell as a complete package. I'll give it two weeks then break it up.
What are you interested in?
Cheers Lee
Old 01-Mar-2019, 21:53   #4
Newbie
Bikes: ducati 600
Im just starting out on a class b bike and am in need of a front wheel early type with twin 320mm discs to complete a spare set for wet set up and could do with it for a meeting at brands on sat 9/3/19 then at the ng racing on fri 15/3/19 I would also be interested in some tyres
Old 11-Mar-2019, 20:45   #5
Lee M's Avatar
Sold!!
Old 18-Mar-2019, 14:46   #6
Lee M's Avatar
not Sold!!!!!!!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:13.
