Old 05-Mar-2004, 17:49   #1
fuel tank removal
can anyone tell me if the fuel connections on my 999 are the sort that seal once you disconnect them?
Old 05-Mar-2004, 19:59   #2
ie if you pull them out, the fuel wont come out the tank?
Old 05-Mar-2004, 20:18   #3
rich999 rich999 is offline
rich999's Avatar
fuel tank removal
If you pull off the fuel pipes from the pump be careful because the fuel is still under pressure and you will get a face full of petrol like I did-not recommended, but once disconnected no petrol comes out, unless you switch on the ignition with the wiring to the pump still connected Hope this helps
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:20.
